squealing noise help please
Old Nov 18, 2005 | 03:34 AM
jedinyte120's Avatar
hey guys,
there is a squealing noise coming from my front driver side. sounds like rubber rubbing on something. only hear the sound when the car is moving.when i go faster the sound is faster,as if its spinning and rubbing on somehting to make the squeaking/squealing noise.i already changed my driver axle but the sound is still there.i thought it was the torn boot but it wasnt. any ideas would be helpful. thanks guys
roger
Old Nov 18, 2005 | 08:07 AM
Tfvesquire's Avatar
Hello: I had the same problem on my 98 SE. It ended up being the rubber boots on the CV joint -- more on the driver's side than the passenger's. I jacked up the car and as I rotated the tire I used some brake cleaner to first clean the boot of dirt, grease and check for any damage. They looked fine so I sprayed them (while rotating the tire) with dry lubricant. Gunk makes one with PTFE which is a synthetic and won't wash off. Don't try WD40 or silicone or it will start to deteriorate your rubber boots. So far squeak has been gone for 3 months. The only downside is that depending on how detailed your suspension is, the spray will leave a little white residue. Can also be used for sticky/slow windows. Same downside applies. Hope this helps!!!
Old Nov 19, 2005 | 01:34 AM
anyone else have an idea? the squeal is also more noticeable when im making a right turn. its not constant but it skips a beat. it is a new axle,so any ideas would be great.thanks
Old Nov 19, 2005 | 01:42 AM
DennisMik's Avatar
my first guess is the cv joint in the axle, but you said you changed it. i also had a squeeling on my 97 and it was the noise-maker arm on the disk brake pad. i could turn the wheel by hand and it squeeled. i didn't think i needed brakes, so i was looking everywhere else for the noise.
Old Nov 20, 2005 | 12:33 AM
the noise sounds more like a"errrr errrr errrr" but a slightly higher pitch. i took apart my brakes and put it back together,so i ruled that out.the sound is there when the car is on the ground,but when its on a lift,the sound is hardly noticeable. i also hear it more when i turn right and its not there when i turn left. sound is there when im pressing on the brakes or just coasting. this noise is so annoying.
Old Nov 20, 2005 | 12:21 PM
mindlessoath's Avatar
i recently found this problem too!
right now i know i need new brakes, and im going to replace them next week. then i will know if it was just brakes or not.
thanks for the info about the boot. my old car had boot problems where they would always tear... mabe i will get new ones or cv joints replaced (i havent a clue).
but more info if anyone has it... this is still a problem until i get it fixed.
also i seem to have it sometimes and not always. its weird... but more often than not it happens. i notice it when the windows open, on my side, its a whirring noise i belive, like somethings rubbing, like rubber or something. i did recently get new tires, i was thinking mabe it was those, but i cant tell that for sure.
Old Nov 20, 2005 | 01:07 PM
Sharp's Avatar
replacing cv joints and axles are no fun..and its scary when they come out and look like the joints have melted and then rehardened
Old Nov 20, 2005 | 02:59 PM
already had the axle replaced. rotors and pads replaced about a month ago.
does anyone know of the link for the search so i can search for some answers?
Old Nov 21, 2005 | 03:38 PM
http://forums.maxima.org/subscriptions.php
you have to subscribe to search here.
or you can try your luck with google.com and mabe include "maxima.org" in your search parimaters.
Old Nov 22, 2005 | 07:48 PM
this sucks ***. i took my car to two mechanics and no one can figure out what the strange noise is. any gurus around the philly area that can help me out.?thanks
Old Nov 29, 2005 | 05:28 PM
jian622's Avatar
front Struts?
Old Nov 29, 2005 | 07:56 PM
Type3max's Avatar
im replyin for jedinyte120.it was his wheel hub.we took it apart and greases the heck out of it and the noise went away.we also took the brakes apart just to see if anything was stuck on the pads. thanks for everyones insight though
Old Nov 29, 2005 | 10:51 PM
Fr33way™'s Avatar
Wild for Width
This is what I looked like when I was doing mine + some grease
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
