Rear Manifold bolt size?
Old Nov 18, 2005 | 09:53 AM
AsthmaMax11's Avatar
Hey does anyone know the specifications of a rear manifold bolt? The dealership has to order it and I'd rather go to home depot and buy it.
Old Nov 18, 2005 | 03:10 PM
naplesmaxima aka Tommyali the scammer!'s Avatar
I scam therefore I am
they are 14mm head i dont know the thread pitch or anything like that
Old Nov 18, 2005 | 03:31 PM
Sin's Avatar
Sin
I'd be careful with using just any plain old bolt. Nothing worse than having a manifold bolt snap, then having to drill and tap. Just wait on the Nissan one, or beyond having the appropriate diameter and thread pitch, you better be damn certain the new one a) can take the extreme temperatures b) can take the extreme cycling of temperatures c) will not gaul on aluminum d) will not seize e) is of the same grade bolt.
Old Nov 18, 2005 | 05:30 PM
damn, now you got me all paranoid
What I'll probably do is take off one of the bolts in the parking lot of Home Depot and bring it in and have it matched. I assume they have the same type of metal used as Nissan?
btw, thanks NaplesMax!
Old Nov 18, 2005 | 05:36 PM
why do you need to replace these nuts?
also home depot isnt a car parts store
you should go to nissan parts department and order the nuts they cant be more than a dollar each
Old Nov 18, 2005 | 05:42 PM
Sin's Avatar
Sin
Manifold bolts are very specialized. There are two threaded portions on the bolt. And they run in opposite directions. One side threads into the block, and one side, threads with a nut that secures the manifold flange. If you can even find such a bolt at Home Depot, I'd be beyond surprised.
Old Nov 18, 2005 | 09:43 PM
ok,
I was trying to put the USIM manifold back on when I was pissed off with my MEVI and I "misplaced" one of the bolts.
I think I will go ahead and order it even though it cost 3 stinkin dollars!
Does anyone think I could have a leak or anything?
Matt93SE
May 24, 2019 02:58 PM
vingodine
45
May 21, 2016 12:46 PM
Huttig2009
Sep 25, 2015 03:31 PM
maximaham
Aug 20, 2015 10:23 AM
MaxStock
Aug 12, 2015 08:33 AM
