wtfenginesqueal.mpg - video
Old Nov 18, 2005 | 10:56 AM
Iron Scimitar's Avatar
Tha Snatcher
http://video.google.com/videosearch?...+playable:true
I took my car to be checked out around a month ago and told the mechanic to inspect the belts. I got the car back and the mechanic said to me that all of the belts are fine. Since then my car STILL squeals when it starts up. Anyone know which belt in particular would cause the squeal?
Old Nov 18, 2005 | 11:05 AM
cardana24's Avatar
Blown
I did not click on your link Karim, because I do not have audio on my computer. But one easy way to find out is by spraying some liquid silicone on one belt at a time. When you spray the belt that is squeeling it should shut it up for a while. Then you will know which one is making the noise. Also check the tension your belts. Grab the belt and turn it, it should turn 90 degrees...if it turns more than that then you may need to crank on one of the belt tensioners.
BigLou93SE's Avatar
OH wow...that sucks. Sorry I can't help you with which belt to look for, haven't come across that problem yet. Good luck
Old Nov 18, 2005 | 11:08 AM
Fr33way™'s Avatar
Wild for Width
Belt tensioner? How does it start when it's already warm?
Old Nov 18, 2005 | 11:10 AM
mbandi's Avatar
Da'Burgh, Go Stillers!
Most common belt to squeal is the a/c-alternator belt. If it can't be tightened anymore, replace it.
Old Nov 18, 2005 | 11:11 AM
MaximaSE96's Avatar
Maxima Owner
i would say jsut snug it up a bit...i had to do that to mine as soon as it started to get cold out here......prolly because i replaced my alternator and during the summer and it was jsut tight enough not to squeal until it god cold
Old Nov 18, 2005 | 11:14 AM
Tha Snatcher
When its warm, it doesn't squeal at all. the longer i have the car off, the more apparent the squeal becomes.
Old Nov 18, 2005 | 11:32 AM
maxima_kenny96's Avatar
its ur alternator belt check the tension on it, sounds JUST LIKE my buddies and that was his problem.
but like said before AC and alternator are ur best bets.
Old Nov 18, 2005 | 11:37 AM
njmodi's Avatar
Do I get a tax break?
I just looked at the video. That is definitely your alternator belt. Did you just replace it recently? If not, replace it. If it's still in good shape, just tighten the tensioner.
Old Nov 18, 2005 | 11:41 AM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
don't spray anything on your belts, unless you want them to fall off
happened to me once, but not w/ the Max
Old Nov 18, 2005 | 11:45 AM
Tha Snatcher
Thanks for the help fellas. It helps when there's a video for you to look at.
Old Nov 18, 2005 | 11:46 AM
Tha Snatcher
The alternator belt hasn't been touched at all.
Old Nov 18, 2005 | 12:06 PM
Mmmaxx's Avatar
I have the same problem, exactly. I had my belts all replaced about 2 months ago. They warned me I might hear a squeal on cold start at some point. He pointed out that the belts aren't bad, but just need to be tightened. Apparenty whenyou put in a new belt it stretchs out and needs to be tightened again. May take 2 tightening to get it to the right spot where it will last long. Before, my belts squealed horribly, but would eventually go away after the car had time to warm up when I looked at them, they were stretched and glazed.
Luckily its fairly easy to tighten the belts yourself, but I dont know which is doin it, so this thread helps me a bit
Old Nov 18, 2005 | 12:50 PM
Fr33way™'s Avatar
Wild for Width
The vid strikes close to home.
I replaced my belts a few months ago because of the squeal and it was comin' up to 60K tune-up time anyway.
When we got in there to swap them out my tensioner was SO loose. I only had the squeal on the 1st start of the morning or after it sat for quite awhile.
That is a MONSTER of a squeal you got, try messing with your tensioner before swapping anything.
Hope you get it solved, I hate small probs. like that....
Old Nov 19, 2005 | 03:45 PM
konak85's Avatar
I had the same thing. I changed the alternator belt with help of the haynes and it hasn't happened since. Be careful though, you gotta loosen the tensioner then tighten the other bolt.
Old Nov 19, 2005 | 04:11 PM
RockfordMax's Avatar
Back from the dead
Mine was exactly the same a couple nights ago. I floored it down the street just to make it go away... Is the tightening procedure in Haynes or Chilton?
O BTW konax grats on almost 1000!
Old Nov 20, 2005 | 12:44 AM
eyesack killa's Avatar
OMG THAT IS THE SAME EXACT PROBLEM I POSTED ABOUT EARLIER!!! thanks so much dude for being able to have a video! now i don't feel so worried about my stupid ear shattering squeeling noise! i thought the cold nj weather might be causing that! anyone have like an online version of the haynes / chilton manuals? if/when i buy one i'll probably post it up.
Old Nov 20, 2005 | 12:53 AM
eLMo's Avatar
It happens for me when I start the car and when it's raining and right after I run over a puddle.
Old Nov 20, 2005 | 10:08 AM
Back from the dead
well ive got both haynes AND chilton, im just too lazy to look, ill post it up in a lil bit.
Old Nov 20, 2005 | 07:12 PM
Fast1one's Avatar
Same here...or morning presperiation when its really cold...could be that...you car isnt outside though is it???
Old Nov 20, 2005 | 07:50 PM
96nismomaxi's Avatar
.org window licker
dude i had the same problem when i bought my max
it ended up being the combo of the tensioner and the belt
well first off the little thing that u crank down dosent mean **** i got rid of mine
all u need is an old fasioned crowbar and some pressure to tigether the 12mm bold on the side of the tensioner
anyway it is one belt that u will have to change it takes like 10 minutes
all u have to do is get under the hood, it is all located on the passanger side of the motor by the horn(looks like a diaphram
u will see a tensioner and a wheel under it about 90mm in diameter loosten the 12mm on the side of the wheel and than start loostening the tensioner (it threads backwards) losten it up till u can remove the belt and get the new one now fish the new one back on the same way that the old one on there (on the a/c underdrivepulleyand up to the top a fiew more things i think that there are a total of 5 pulley's that u will have to include (I THINK)
anyway have fun and to everyone else if this is happening to ur car get it changed soon if the belt pops than BAM mo more car running it does go arround the alternator and without that that means no power for the car !!!!
Old Nov 20, 2005 | 08:24 PM
culejoe's Avatar
yea i had the same issue aswell... just replaced the belt no more sounds....
Old Nov 23, 2005 | 01:08 AM
Yeah, come to think of it, it really only happens with cold perspiration in the mornings or if it's wet out/puddle hopping
AaronL
Aug 8, 2020 10:31 AM
Need help
23
Oct 2, 2015 08:56 AM
jaydot901
Sep 29, 2015 01:18 PM
rbaker100
Sep 25, 2015 07:52 PM
