Terrible Sound - Need your help
Old Nov 22, 2005 | 06:21 AM
impliedparadox's Avatar
I have a strange sound that comes from the front of my car occasionally. It sounds and feels like the tires/brakes. The sound is like metal rubbing against metal (not a high pitch squeek). It sounds more like the caliper assembly fell off and it is dragging or rubbing against something (obviously this did not happen because I would be dead right now). It only happens when I am going very slow and when I am going slow and braking. It does not happen all the time though.
On a side note, I do think it is time to change the pads on the front but this is not the typical "brake pads need to be replaced" sound - the brakes give a bad grinding sound when I brake hard (it may just be that my rotors need to be turned (I still do not think this is the only problem I am having). So, what the heck am I hearing?
I am sorry this is so long, thanks for trying to help.
Old Nov 22, 2005 | 06:52 AM
njmodi's Avatar
Do I get a tax break?
Did you check the pads? My guess is you have worn down all the wear material off the pads and are grinding the pad-backing metal against the rotor.
Old Nov 22, 2005 | 06:55 AM
Chapman99SE's Avatar
I have the exact same sound
just had my brakes done and pads replaced 2-3 weeks ago which is good cause i have somebody to get loud at about it now,
maybe they ****ed something up, or it could be completely unrelated to the brakes (you never know)
Old Nov 22, 2005 | 07:13 AM
I will check this after work, I have not looked at it too hard yet. Thanks for the tip.
Old Nov 22, 2005 | 07:18 AM
MaximaGLE97's Avatar
could be that your caliper is getting stuck at times?
Old Nov 22, 2005 | 07:21 AM
ColdSHO's Avatar
maybe its just the brake shield rubbing on the rotor, those are bent easy and can be quite loud, u can just push it away fromt he brake without taking off the rim, just use a long screwdriver or soemthing liek that and push/bent/rebend the shield back.
Mahmuth
Aug 16, 2024 08:23 PM
AaronL
Aug 8, 2020 10:31 AM
Need help
23
Oct 2, 2015 08:56 AM
Andy29
Sep 29, 2015 05:32 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
