problems running shortly after cold start
Old Nov 22, 2005 | 07:29 PM
valentine1's Avatar
As the title says, my Max has a problem staying started shortly after starting it on cold mornings (<40 or so). I will go out to start it for the first time of the day and it will crank up without a hitch but afterwards I have to keep the RPM's up around 2K or so for 10-15 seconds or it will die and the process starts all over again. After about 10 seconds of giving it gas it runs normally. I have no CEL and the only code it's throwing is the all-to-familiar KS code(soon to be fixed). Could this have something to do with idle air or air temp?
Old Nov 22, 2005 | 07:42 PM
f550maranello2's Avatar
i would check (clean) the idle control valve.. as well as the fast idle cam....
Old Nov 22, 2005 | 07:45 PM
valentine1's Avatar
Thanks for the quick response and the advice. What/where is the fast idle cam?
Old Nov 22, 2005 | 07:46 PM
a3gus's Avatar
Check this out... maybe it will help.
http://www.jatan.net/tsbs/044578.pdf
Old Nov 22, 2005 | 07:48 PM
look at where the throttle cable attaches to the throttle body... there is a large black spring.. that you cant lift up... thats it.. (sorry kinda weird explanation)
Old Nov 22, 2005 | 08:01 PM
valentine1's Avatar
OMG, I feel like an idiot. It says in the owners manual "If the engine is very hard to start in extremely cold or hot weather, depress the accelerator pedal and hold it to help start the engine". I must have read this thing 10 times and don't remember reading that. I guess it's normal. Thanks again.
Old Nov 22, 2005 | 08:04 PM
uhhhh..... dont do that when its cold man its pretty bad......its not normal at all... just check what i told you too...
Old Nov 22, 2005 | 08:05 PM
valentine1's Avatar
Alright, will do.
FlaMark
Aug 21, 2015 11:06 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
2k0to2k3
Aug 18, 2015 09:59 AM
acw
Aug 13, 2015 12:50 AM
kirkhilles
Aug 8, 2015 10:53 AM
