solar battery charger?
Old Nov 22, 2005 | 07:30 PM
pMak26's Avatar
anyone know if one of those solar battery chargers will work on a maxima??? they plug into the cig. lighter to charge battery, but i'm doubting maxima's have the electrical hookup to the battery to do this.
thanks
-paul
Old Nov 22, 2005 | 07:39 PM
f550maranello2's Avatar
I wouldnt waste my money that man....
Old Nov 22, 2005 | 07:52 PM
valentine1's Avatar
That's what an alternator is for, don't waste your money on it. Spend it on something to make your car faster.
Old Nov 22, 2005 | 09:07 PM
Garrick's Avatar
Sounds like a sad attempt from Pimp My Ride.
Old Nov 22, 2005 | 09:51 PM
pMak26's Avatar
pimp my ride... hah! no way man, but something is slowly draining my battery and i wanted borrow the solar panel that comes with VW cars just for tomorrow to keep a charge in the car. dont have time to figure out exactly what's wrong... while im at it, any ideas? anyone think it's the blitz turbo timer?? regulator?
-paul
Old Nov 22, 2005 | 10:28 PM
ryant35's Avatar
thanks
-paul
No, Maximas have a anti-charger valve that right next to the blinker fluid pressure regulator.
This will work as well has on any other car, if it works on any other car at all..
If it charges throught the cig lighter, how do you figure that a maxima does not have a hookup to the battery? How do you think the lighter is powered? From wind turbines located under the hood. Thats why the lighter only works on windy days and at high speed.
Old Nov 22, 2005 | 10:51 PM
TurTLe*'s Avatar
^lol.... well yea i was just about to say that VW have them. VW have them on their cars but i don't think it will work for our max. Because VW's are wired up diffrently then us. For instant radio can be turned on w/o key in the ignition. I think you can plug it in. But power won't be going to it unless you have the car on. That also might blow your fuse for the cig lighter since it wasn't really design for that as well.
The solar panel cig charger was design for new vechile that sit on the lot to maintain some battery life. since no-one really touches them untill they are sold. Great idea VW came out with, but don't see how it will help out a maxima.
Old Nov 23, 2005 | 12:50 AM
eyesack killa's Avatar
you should just put a bigger pully on your alternater's piston so that the ratio is better than 1:1 and you'd get a bigger charge to your battery! ... sorry don't mean to flame, but it was just too tempting. that does sound like a neat idea tho!
Old Nov 23, 2005 | 03:51 AM
MaxKlinger's Avatar
It's for VW's. Keep it out of your car, otherwise you will have a lot of problems. It will start burning oil, you will have electrical problems up the @ss, and your water pump will fail. Your car will be called cute. But your glove box will be refrigerated.
Old Nov 23, 2005 | 06:18 AM
sonicrunch's Avatar
you are the dumass here ryant. think before you speak.
The solar chargers do work, but since our cigarrette lighter is disconnected from the battery when the key is off, the solar charger will not charger the battery
Old Nov 23, 2005 | 06:19 AM
sonicrunch's Avatar
you are a dumass too
a bigger pulley will slow the alternator down
Old Nov 23, 2005 | 08:17 AM
maxgtr2000's Avatar
KH3 by popular demand
It would work okay in the back window if you have an extra battery in the back for audio or if your main battery was relocated there, but they are trickle type chargers, and take a while to charge up the battery.
Old Nov 23, 2005 | 08:21 AM
kormax97
What about at night?
Old Nov 23, 2005 | 08:22 AM
buttonhook's Avatar
they would be good of your car was going to sit all winter
Old Nov 23, 2005 | 08:24 AM
pMak26's Avatar
yup, thats what i thought. thanks to those who gave useful info.
charged the battery last nite and drove the car... woke up this morning, tried to start it. damn thing is dead again. i hate electrical ****. Yes the battery was reloc. to the trunk. anyone have any ideas as to what's up?
Old Nov 23, 2005 | 08:54 AM
sonicrunch's Avatar
If I were you, I would disconnect the battery when the car is not in use.
Repeated discharging of an automotive battery will surely destroy it in short order.
Only deep-cycle batteries are meant to be fully discharged and recharged.
There are try something like this
Old Nov 23, 2005 | 09:00 AM
GodFather's Avatar
Made in Taiwan
battery draining out? must be a fauty alternator component. you should check the voltage regulator for the alternator first. if not, you should just simply replace the alternator. i had discharging problems before, and few days later, alternator fails. both brake light and batt light came up on the instrument cluster...
Old Nov 23, 2005 | 09:17 AM
sonicrunch's Avatar
^^^ It is likely to be the alternator.
Old Nov 23, 2005 | 09:31 AM
pMak26's Avatar
alright, thanks guys. u think it's worth it to pick up a junkyark alt.(since VQ parts plentlyful) or just buy new?
Old Nov 23, 2005 | 11:15 AM
GodFather's Avatar
Made in Taiwan
buy a new one from autozone, their charging capacity is higher than the stocks, also.
in addition, make sure you list your name and address info to their system to settle for that lifetime warranty stuff. that way, later if it goes kaput again, just take it off and swap it with autozone for free.
Old Nov 23, 2005 | 12:07 PM
sonicrunch's Avatar
make sure the battery is fully charged too. Don't make the alternator recharge your battery. It's could overwork/heat/wreck your new alternator.
Old Nov 23, 2005 | 03:56 PM
jkslaughter@hot's Avatar
The solar charger won't work through the cigarette lighter on the max as the key has to be on for the lighter to be connected. But you could wire in another lighter socket that is on all the time or rewire the existing lighter to be a direct always on connection and it should work. The solar chargers work good for keeping a battery hot if the car is not driven frequently. Some security systems will drain even a good battery over time and is one reason VW provides them, but this could also cause trouble with use of the chargers because some security systems are activated by fluctations in battery voltage. ( light comes on =voltage fluctuation=alarm ) I'm not sure if that would be an issue with chargers on the Max. Not exactly the same thing , but we use a solar charger on a houseboat with great results
Old Nov 23, 2005 | 04:10 PM
the_3d_man's Avatar
thats good advice.
Check the battery voltage. it should be about 12.6 volts fully charged. If it's below 12 volts it's never a bad idea to slap it on the charger for a while before driving (this would be a tempory thing). That way if there is nothing wrong with your alternator you won't put it at risk. (still go get it tested at austozone)
Old Nov 29, 2005 | 12:14 PM
MaxKlinger's Avatar
Just be careful you don't overcharge it, you can easily destroy a battery that way.
Mahmuth
Aug 16, 2024 08:23 PM
litch
123
Jan 4, 2024 07:01 PM
gigabyte
Jan 6, 2017 06:05 PM
bigfrank
Oct 1, 2015 12:51 PM
