Temp Sending Unit? I think....
Old Nov 23, 2005 | 10:26 AM
TJ_Max's Avatar
Paradox Systems Vendor
What is the name of the part or parts that can lead to a temp gauge showing incorrect temps....i would start the car, cold, and the needle would shoot all the way up...i overheated once, but fixed that problem. but my gauge was never normal since then. i want to get it replaced, but im a do it ureselfer...sooo...
is it called the "temperature switch", "sending unit"? how do i tell nissan what part it is...i called and tried to explain and they just kept saying, bring the car in...
i changed my thermostat, and im not oveheating, its just showing i am though...needle sometimes starts going up and down fast also..... help!!! thanks guys
Old Nov 23, 2005 | 10:33 AM
NmexMAX's Avatar
dot dot dot ...
ECTS ........Not the one that causes stalling.
Old Nov 23, 2005 | 11:07 AM
TJ_Max's Avatar
ECTS, engine control temperature sender? wuts that stand for..... and i really have to specify that its not the one that causes stallling? and is it expensive, easy or hard to install?
Old Nov 23, 2005 | 11:25 AM
njmodi's Avatar
Do I get a tax break?
Actually ECTS does not control the gauge. It is only used by the ECU. The sensor that is used to control the gauge is called the Temperature Gauge Sending unit (or something like that).
Old Nov 23, 2005 | 11:44 AM
TJ_Max's Avatar
ok, is that expensive?
Old Nov 23, 2005 | 12:16 PM
njmodi's Avatar
call a parts place
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
jaydot901
Sep 29, 2015 01:18 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
