Weird thing happened to me with the speedo
Old Nov 23, 2005 | 12:27 PM
kormax97
Alright so I was home first week of this month and took a trip with my max to boston to see my cousins. It was about 250 mile trip each way. On the way to boston I was cruising along at around 80mph but about 130 miles in to the trip, I noticed that my mileage wasn't going up anymore. So I slowed down to a complete stop on the side of the road and my speedo was stuck on 80 but everything else was working like to tach, etc. I turned my car off and the speedo went to 0, and started it back up. I started going back to the speed of the traffic and the speedo was then stuck on 0 and mileage wasn't going up still. So now I was, great... this pieace of ****... now I have to spend more money... After about 50 miles of driving with 0mph on my dash, all the sudden my speedo needle does 0~80 in a second flat and starts working again. I was happy but afraid it'll happen again.
So what was the problem there?
Old Nov 23, 2005 | 12:30 PM
njmodi's Avatar
Do I get a tax break?
Bad speedo head?
Loose connection?
Old Nov 23, 2005 | 12:37 PM
kormax97
Originally Posted by njmodi
Bad speedo head?
Loose connection?
I thought the loose connection myself when it stopped then working again, but since I've never taken apart the speedo on the max before I didn't want to. On the VW Golf winter beater I have, the whole cluster is connected to only 1 connector... but anyways, hopefully it doesn't happen again..
Old Nov 23, 2005 | 01:21 PM
alphaerror's Avatar
i had something like this happen recently, but i unfortunately dont know what the problem is. i havent touch the cluster yet either so... hopefully it ll just stay workin. if not, good reason to change the lighting in there
Old Nov 23, 2005 | 01:29 PM
Nismo3112's Avatar
Custom User Title
My speedo always gets stuck at ~40mph, and depending how fast I am going above 40, it will then jump up.. Very annoying!
Old Nov 23, 2005 | 02:13 PM
Tim96I30t's Avatar
It will eventually get worse and cel will come up ( speed sensor ) replace the whole cluster.
Old Nov 23, 2005 | 03:40 PM
MaDMvD's Avatar
Listen to my story, as it pertains to most of you! Starting a few months back I began having the same problem - speedometer would stay at 0, not count any miles, then all of a sudden jump right up to the speed I was going. A short while after, I got the speed sensor CEL. Replaced the speed sensor and it did nothing. I followed the recommendation by fellow .ORG members and removed the cluster, tightened all the screws located on the back, and put everything back. Problem solved - for about a week. It started acting up again shortly after and has been ever since. The only obvious advantage is that it's not marking any miles when it doesn't work, but if I flick the needle, it jumps right up. Now I know most of you are probably thinking - why fix it if it's technically preserving the value of your car? Well, I talked to a tech about it and he says that if left unfixed - over a period of time - it can screw up the way your transmission shifts (automatics). I am in the process of looking for a new cluster, as I've been having some ocassional slipping Hope that helps, good luck guys!
Old Nov 23, 2005 | 04:29 PM
Nismo3112's Avatar
Custom User Title
Why would the guage cluster have anything to do with the transmission slipping?!?!?!?
Old Nov 23, 2005 | 04:30 PM
MaDMvD's Avatar
I'm guessing because the speedometer is what tells the transmission when to shift, since it's all speed-related.
Old Nov 23, 2005 | 04:36 PM
Nismo3112's Avatar
Custom User Title
Good thing I have a 5spd.
DJLAX152
May 4, 2021 11:46 AM
mvm062
Nov 30, 2020 09:00 AM
Mar 12, 2020 12:06 AM
jsmith24
Feb 1, 2016 12:35 AM
