car jerks at 1800 rpm in 1st and nuetral...please help
Old Nov 23, 2005 | 04:04 PM
super6's Avatar
figure i try 4th gen forun also....
i cleaned my tb and aicv, put everything back together (minus restricter plate), and adjusted tps (.500 idle - 4.000 wot). now when im in first the car starts to jerk when it gets to 1800-1900rpms, then revs past and is fine. all other gears ok. when i rev in nuetral it just bounces and wount rev past 1800-1900 unless u give it a LOT of gas.
maf changed 4k ago. i haerd tps syptom is when u cant rev past 1900-2000 but mine eventually does. anyone know the problem here? thanx.
Old Nov 25, 2005 | 08:44 AM
super6's Avatar
bump...........
Old Nov 26, 2005 | 09:21 AM
super6's Avatar
common anyone?
Old Nov 27, 2005 | 06:23 PM
super6's Avatar
need some help here
Old Nov 28, 2005 | 11:26 PM
super6's Avatar
last try............
Old Nov 28, 2005 | 11:57 PM
nadir_s's Avatar
vicodin ... gift of life
yeah, that problem sounds like the car is in "safe mode" when the MAF screws up or dies ... iv'e had that issue but it happened to me twice and never again ... strange. Make sure the MAF is plugged in properly.
Where did you get the replacement MAF? Is it OEM?
Old Nov 29, 2005 | 01:04 AM
MorpheusZero's Avatar
Second that, if you're aftermarket chances are it's the MAF. If you're OEM, check it anyway, sometimes it can get damaged during shipping etc.
Try pulling some codes.
Old Nov 29, 2005 | 08:55 AM
super6's Avatar
maf is oem ans was changed about 4k ago
Old Nov 29, 2005 | 09:17 AM
JUS
Mine Does It Around The Same Rpm. But It Still Drives Strong And It Only Does It In When Getting Out Of First Gear
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
beboski
Aug 16, 2015 05:23 PM
maxima297
Aug 3, 2015 12:50 PM
