Hard to open rear doors
Old Nov 23, 2005 | 06:34 PM
Obespalov's Avatar
I've been meaning to ask this for a while. My rear doors, probably through minimal use, are very difficult to open and close. I don't know if it's rust or what, but I've sprayed WD40 there and it really doesn't help. Has anyone else had this problem?
Old Nov 23, 2005 | 07:29 PM
Rbhays's Avatar
i would suggest going to the gym and pumping some iron. that should fix it
Old Nov 23, 2005 | 08:00 PM
MaxMateo5's Avatar
I got the same problem with my 95, makes an awful squacking sound too... no luck with wd-40 either..
Old Nov 23, 2005 | 08:21 PM
eyesack killa's Avatar
hahaha i thought i was the only one so i kept my mouth shut. yeah, people would try to slam them shut and they like wouldn't close! i think if you just keep opening and closing them, the joints'll loosen up over time. it's like the doors have arthritis.
Old Nov 23, 2005 | 09:01 PM
tcrow31's Avatar
damn i thought i was only one as well, so any one got a clue on whats up with the rear doors?
Old Nov 23, 2005 | 09:03 PM
Nissan 6's Avatar
i had this problem onmy old gxe and put a lot of black grease on there, sort of helped. but really told the passengers to go out the other side
Old Nov 23, 2005 | 10:13 PM
crazy97's Avatar
Mine were like that, wd40 worked for me, I just had to make sure and spray real good and work it in a bit. They are loose now.
Old Nov 23, 2005 | 10:23 PM
MaxMateo5's Avatar
tru WD40 helped my driver rear door when I opened and closed it 30 times straight, didn't make it over to the passenger side tho..
Old Nov 24, 2005 | 05:29 AM
njmaxseltd's Avatar
If WD-40 on the hinges doesn't loosen things up, then it could be your door check. Thats the black arm that holds the door from swinging past it's limit. It's a $30 part from Nissan.
Old Nov 24, 2005 | 07:59 AM
Black Maxima
Silicone Grease work good too.
Old Nov 29, 2005 | 11:14 AM
JUS
My 95 Se Back Doors Are Hard To Open Too. I Havent Tried To Spray Anything, But I Will Try Some Of Yalls Suggestions. I Hope It Works, Thanks.
Old Nov 29, 2005 | 11:15 AM
NmexMAX's Avatar
dot dot dot ...
I can see it now ... 15 posts ... ...
Old Nov 29, 2005 | 11:18 AM
tomservo291's Avatar
Mine too, no grease/WD40 has worked yet.
First it was my passenger side only, then one day I was closing it and there was this HORRENDOUS snapping sound... much to my dismay I exclaimed oh **** thinking part of the hinge must be broken!
Much to my delight however, nothing apparently broke and all of a sudden the door works just fine, nice and smooth...
Now my driverside is stiff, but the passenger side is still fine after its little "episode"
kinda weird.
Old Nov 29, 2005 | 11:29 AM
njmodi's Avatar
Do I get a tax break?
It's actually a defect. These parts were updated and it's a problem on at least the 95/96s and perhaps even early 97s. Nissan refused to fix mine under warranty (because it wasn't a recall), but there is indeed an updated part. It's also known as a door-stay. (The same part Tom refers to in his post above).
My rear doors get much stiffer in winter... but I don't feel like pulling the door panels off to change the parts...
Old Nov 29, 2005 | 11:51 AM
joosdawg's Avatar
I dont know if those parts were updated because my 99 did the same thing so i just didnt use the door because it was kinda hard and sqweeled alot when using it. My 95 and 97 both havent had that problem though.
-Ryan
Old Nov 29, 2005 | 11:54 AM
For the record (I had that one that snapped two posts back,)
My rear doors never made any noise, they were merely stiff (very stiff,) but no squeaking, squeeling of any sort.
Old Nov 29, 2005 | 12:12 PM
njmodi's Avatar
-Ryan
See here: http://home.earthlink.net/~maxfaq/maintenance.htm#hinge
Old Nov 29, 2005 | 03:28 PM
Jatan's Avatar
Had this problem and sprayed WD40 on it but didnt help much until I sprayed it from the bottom (was spraying only from the top before)
Old Nov 29, 2005 | 04:08 PM
mad-max98's Avatar
i bench 350lb and still have hard time openning my rear doors lol
vingodine
45
May 21, 2016 12:46 PM
Huttig2009
Sep 25, 2015 03:31 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
shaunkey1
Aug 18, 2015 10:09 PM
