rear shock assembly...creek
Old Nov 25, 2005 | 09:21 AM
MDeezy's Avatar
I am getting a creek comming from the rear, it just poped up about 2 weeks after everything being put on. First it was the driver side then I realized I could hear it on the passenger side rear as well.
KYB AGX w/S-tech
Bens Mounts
Spring were seated propely.
Isolators are covering the spring all the way
The sound is similar to Styrofoam, or rats... and I know I dont have rats back there.
When I re-installed the rear shock on both sides I forgot the red thing that is ontop of the shock assembly. They were in bad shape, but should be about $10 at the dealer.
Could lacking this on the shock assembly be the cause of the noise?
If so Why wouldnt the rear have made noise the next day after installing versus 2 weeks later? (maybe all the WD-40 I sprayed??)
Also, I havent gotten my alignment, since the rear is non-adjustable and basically as long as the front is in spec the rear will be, doesnt this mean the rear could be taken off and put back on many times and still be in spec as long as the front isnt touched?
Thanks all.
Old Nov 25, 2005 | 10:04 AM
EteRnity059's Avatar
Boosted?....
I had the same problem and it was because the strut mounts were bad. The rubber bushing pretty much decinigrated because the installer over torqued the bolt.
Old Nov 25, 2005 | 12:48 PM
RockfordMax's Avatar
Back from the dead
MDeezy you bastard, I think your sabotaging my car. Exact same problem. Im sure the cold is making it noticable, because in a year i havent heard it once, now it happens. I hate you lol
Old Nov 25, 2005 | 01:03 PM
CreativeDesignz's Avatar
haha same thing here too man you really are bad luck!
Old Nov 25, 2005 | 01:32 PM
MDeezy's Avatar
All the rubber ont he shock assembly was in good shape, nice and rubbery still. I believe the red thing I was talking about (I know the name but its saved in my parts file at home) maybe the source, I will put them back on tommorow, but I wanted to get peoples advice incase when I put it back on, it doesnt solve it.
Your just recently poped up too? wow what a coincidence. I'm going to do some fenagaling with it tommorow, I let you know if I solve it and how...
Is your clutch acting up too?
damn you too! Wow. . .
... is your tranny acting up also??
Old Nov 25, 2005 | 01:40 PM
RA030726's Avatar
I'm nutty for Nissans
the oem red gasket sucks. i made new ones using a sheet of gasket material.
Old Nov 25, 2005 | 02:04 PM
nope tranny is good to go soon to be 3.5'ed and AE 5spd'ed
Old Nov 25, 2005 | 02:07 PM
MDeezy's Avatar
How did you go about this? Did you purchase the material from a local auto store, and just cut to shape the top of the assembly? The oem gasket was in bad shape when it came off, and looks thin and flimsy, would rather make the gasket and have a better one.
you lucky bastard, I hope to join you soon. Gotta get my car working right first. . . damn tranny
Old Nov 25, 2005 | 02:14 PM
njmaxseltd's Avatar
Make sure the nubs on the rubber bushings holes fit securely in the mount's center hole. That centers the shock and isolates the piston from the mount, which could be the source of some noise.
If the bushing nubs are all worn, get new ones. Tokico provides new bushings with their shocks.
Old Nov 29, 2005 | 05:25 PM
jian622's Avatar
same..........my shocks are leaking and i realized it creeks when its cold .......have it replace........
Old Nov 29, 2005 | 06:25 PM
MDeezy's Avatar
mine dont creek when its cold, it creeks period. I'm sure the shocks arent leaking but I'll double check.
I believe its the rubber bushing that needs adjustment, gotta do it this weekend when I can rent a impact wrench and spring compressor again.
Old Nov 29, 2005 | 06:28 PM
RA030726's Avatar
what do you need an impact wrench for?
Old Nov 29, 2005 | 06:42 PM
sonicrunch's Avatar
WTF
mine too.
Old Nov 29, 2005 | 08:32 PM
MDeezy's Avatar
to use in conjuction with the spring compressor in order to take apart the rear shock assembly. I dont want to do it by hand, would tire me out fast.
matts95max
Apr 23, 2025 10:44 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
Violator
Sep 9, 2015 10:14 AM
