How does your engie start?
Old Nov 25, 2005 | 03:21 PM
Fork's Avatar
Maximaler Experte
When I start my engine cold, it immediately jumps to ~ 2100 rpms, then it goes back down to ~1100 after a few seconds and finally after 1 minute it lowers down to the norm 750-650rpms.
Is that normal? The high-jump in RPM's when it first starts? Just curious to see how other 4th gen's start.
Old Nov 25, 2005 | 03:37 PM
Batxel's Avatar
blah
Yes that sounds normal for a cold car. Every car I have ever driven does pretty much the same thing. It should be a little bit lower like 1600 or so revs but depends on how long the car has been sitting and how cold it is
Old Nov 25, 2005 | 03:39 PM
Capital15's Avatar
Same here. High RPM jump at first...than back to 750-850.
Old Nov 25, 2005 | 03:40 PM
dayglo's Avatar
yea mine too
the 'high jump' in rpm to 2k and it hangs for a second, drops to idle. your car is normal
Old Nov 25, 2005 | 03:54 PM
pmohr's Avatar
No more Maximas...
Just went outside and checked mine, doesn't go higher than 1300, when I start it up it jumps to about 1100 then hovers there, and the RPMs slowly raise.
I'm bored, so here's a small vid of it (keep in mind it's like 36 degrees at best out there, and it hasn't been turned on in a few days): Video.
Crappy lighting out there, and small res so as to keep the file small for those on 56k.
Old Nov 25, 2005 | 03:58 PM
TurTLe*'s Avatar
sounds very normal. aleast nothing to be worried about. pontiacs start up diffrently tho. At some points they scared me upon start up.
Old Nov 25, 2005 | 04:19 PM
99grnmaxgxe's Avatar
Yeah mine always stays at 1100rpm and when I shift to reverse, it drops to normal idle around 700rpm.
Old Nov 25, 2005 | 09:53 PM
maxima_kid's Avatar
Its a engine warm up precedure programmed in the ecu for safety precautions on engine internals.
Old Nov 26, 2005 | 07:16 AM
tomservo291's Avatar
that's why we have a IACV isn't it?
Old Nov 26, 2005 | 08:26 AM
96customax's Avatar
when my cars real cold it take a few trys to get it to start and i have to give it a little gas. Also, sometimes when i have to do this it makes a horrible grind noise in the engine.. very worried about that one
Old Nov 26, 2005 | 03:53 PM
maxima_kid's Avatar
Youre probably cranking it too long. That or a dying alternater. But an alternater squeeks not grind, so scratch that.
Old Nov 26, 2005 | 07:06 PM
thisisausername's Avatar
whats a engie?
Old Nov 26, 2005 | 07:29 PM
Tatanko's Avatar
Bacon Lover
Originally Posted by thisisausername
whats a engie?
It's the gansta way to say "NJ" (for New Jersey).
Old Nov 26, 2005 | 08:17 PM
nismology's Avatar
Wouldn't that be "enjay"?
Old Nov 26, 2005 | 08:30 PM
Tatanko's Avatar
Bacon Lover
Nahh, that's the old way to say it. Now it's "enjee" Have to say it like you have a speech impedement or something
venturous's Avatar
I wish mine did that. I just put a 96 Infinity engine that had been sitting on a shelf for a long time in my 96 maxima that the engine was locked up in when I bought it. When I got it in and tried to start it, it would not fire. It was getting fire and fuel pressure. I changed the front three injectors from out of the other engine and it fired up and then picked up another cylinder. At the present time it is still running on four cylinders. I guess tomorrow I will take the intake manifold off both engines and swap out the other three injectors unless anyone has any better ideas.
Old Nov 27, 2005 | 10:18 AM
Rich1995's Avatar
my engine goes
"breeee breee brreee vrooooooom" and sometimes i like to add some more "VROOOOOOOM VROOOOOOOOM" to it just to waste gas
Old Nov 28, 2005 | 03:15 PM
chk34kk's Avatar
My engine starts the same as yours, at a high of 2500.
Old Nov 28, 2005 | 03:46 PM
JUS10's Avatar
Yea Mine Too
Old Nov 28, 2005 | 05:42 PM
ohflguy's Avatar
Sure seems common to me. My GLE does the same thing and I know the engine is in good shape.
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
trungg86
Sep 4, 2015 04:58 AM
