Changed Rear Brakes- Oil Leak??
Old Nov 25, 2005 | 08:01 PM
JUDE's Avatar
Changed my rear pads & rotors on the Maxima. I used a caliper piston compressor to move it back into place. Not sure If it went too far, because some oil started coming out from the caliper boot. Did it spring a leak or is this normal/ok?
Old Nov 25, 2005 | 08:17 PM
matty's Avatar
No oil should be coming out of anywhere unless you had the bleeder open. If its a leak by the boot you may need to either rebuild or replace it.
The rear maxima calipers are known to go bad early and seeze up
-matt
Old Nov 26, 2005 | 02:21 AM
1996blackmax's Avatar
Did you have the tool that allows you to spin/turn the caliper piston back in, or did you just push it back in. Either way it should not be leaking any break fluid.
Old Nov 26, 2005 | 04:01 AM
wcasskicker's Avatar
No fluid should come out from the piston dust boot. Like matty said, only bleeder screw or disconnecting brake line.
I guess your dust boot is worn, and you should purchase a caliper rebuild kit which contains new dust boot, new O-ring. Fix the probem ASAP, or else you will lose pressure in the brake system.
Old Nov 26, 2005 | 04:08 AM
Frank Fontaine's Avatar
Even with the kit you have to be careful--it can be used on the front as well, where you simply compress without turning the piston. When I first bought mine I didn't realize that I wasn't twisting, but luckily I didn't force it, I just figured based on the responses from the org that my calipers were seized. I finally used logic and determined that since my parking brake worked 100% as far as holding the vehicle and releasing, that there was no way/no how my calipers were seized. I then used the proper adapter and the pistons went in like butter.
Even though the tool is mechanical, sometimes it takes a careful look/see to make sure one's using it properly....my .02.
Old Nov 26, 2005 | 05:29 AM
JUDE's Avatar
I used the tool that allows you to spin it back in place, but I might have pushed it in too far. That's when some oil started leaking out.
Old Nov 26, 2005 | 01:41 PM
SMX95's Avatar
brake fluid.....
MatthewsMaxima
Sep 11, 2015 03:21 AM
rtirbany
Sep 8, 2015 11:46 AM
homeyclaus
Sep 3, 2015 06:15 PM
acw
Aug 7, 2015 04:20 PM
RealityCheck
Aug 5, 2015 06:18 AM
