key turning problems.....
Old Nov 28, 2005 | 05:14 AM
santiagomax97
My car is acting up sometimes i think it is my starter actually it insnt everytime turn on my car i have turn my key more than 3 times to get it running, no click or noise but power still there.any ideas to get this running properly..
Old Nov 28, 2005 | 05:21 AM
JwaxMax99's Avatar
Originally Posted by santiagomax97
My car is acting up sometimes i think it is my starter actually it insnt everytime turn on my car i have turn they key more than 3 times to get it running, no click or noise but power still there.any ideas to get this running.
Ignition switch?
Old Nov 28, 2005 | 05:29 AM
santiagomax97
Originally Posted by JwaxMax99
Ignition switch?
yes the ignition switch
Old Nov 28, 2005 | 05:31 AM
JwaxMax99's Avatar
Yes, I meant it's possibly bad. Under the steering wheel. 30 bucks for the part at the dealer.
Old Nov 28, 2005 | 05:33 AM
santiagomax97
oh really........thats cheap.thanks alot.
Old Nov 28, 2005 | 06:02 AM
Jatan's Avatar
My car starting wasn't that bad, but sometimes ran into a problem of it not starting the first time (alwys started on the 2nd try) - replaced the ignition switch before it got worse so I wouldn't be stranded somewhere
Also make sure that your battery terminals are clean
Old Nov 28, 2005 | 09:22 AM
dgeesaman's Avatar
Maintenance Monster
Another possibility is a bad crank or camshaft position sensor. Mine would intermittently not crank due to that, and I didn't get an ECU code until it was happening consistently.
However, my first bet is the ignition switch - many Maximas have had this problem.
Dave
Old Nov 29, 2005 | 07:53 AM
tomservo291's Avatar
I had the EXACT problem you're describing from time to time:
Full power on ACC (headlights, interior etc were fine,) but turn the key and NOTHING happened (starter didn't do anything.) I thought this was the ignition switch, but in the end it was actually the starter acting up and on its way out.
I would sit in my car for ~ 10 minutes and then try again and it would be fine for weeks, then it would happen again the same way.. until finally the the starter started cranking slower and then click click click...
Good thing it's easy to push start our cars
Old Nov 29, 2005 | 08:03 AM
jtmaxima's Avatar
Is the ignition switch hard to replace? Any how to doc's?
Old Nov 29, 2005 | 09:37 AM
madcatmk2's Avatar
Try checking the battery teminals and the negative wire to the car first. I had a similar problem twice before. First time on my old car it was the negative wire having a bad connection to the body and 2 days ago on my max the terminals were thinly coated with corrosion and it again hapened just as you described until my dad cleaned them while I was at work. Problem was fixed both times.
Old Nov 29, 2005 | 03:06 PM
jtmaxima's Avatar
OK the car is fixed!! I replaced the ignition switch(located on the opposite side of the ignition cylinder). Easy to do just 2 screws and a harness connector. Starts every time now. I didn't realize there was a separate ignition switch and cylinder. That's kind of nice since you only have to replace the switch if it's bad and not the key and cylinder. It's a drag when you have to have 2 different keys that look the same but only work in one location. Oh, by the way it was only $30.
Old Nov 29, 2005 | 03:10 PM
Jatan's Avatar
Good to hear
tarun900
19
Dec 20, 2021 06:57 PM
gavin68
Sep 18, 2021 12:36 PM
Fbana41
Aug 29, 2016 12:18 PM
RealityCheck
Oct 2, 2015 06:34 PM
