NO Air coming from Vent ??
Old Dec 1, 2005 | 02:46 AM
Reaction021's Avatar
i try to turn on my heat today cause it was cold outside but there was no air coming from the vent no matter what speed i turn on the fan to could it be a blown fuse or something else i have no idea what happen any help would be greatly appreciated
Old Dec 1, 2005 | 04:35 AM
njmaxseltd's Avatar
Check the fuse
Does it work on the highest setting? If not, and the fuse is good, chances are it's the blower motor. Make sure you have power getting to the motor before you go and change it. If there is no power to the motor, trace the circuit back to the switch.
Old Dec 1, 2005 | 10:55 AM
thanks i will have a look at it
Old Dec 1, 2005 | 11:13 AM
NmexMAX's Avatar
dot dot dot ...
Maybe switch to the vent mode, where it hits you in the face.... Not your feet
Old Dec 1, 2005 | 12:33 PM
NCSUpilot's Avatar
Do you have automatic air with digital temp control? If so, there is no resistor, the connector just attaches to the motor. So just check the blower motor, I just had that problem. Basically the bushings on the coil of the motor were worn out. Try hitting it while it's on, see if that knocks a little life into it. I extended the life of mine about 2 months just by hitting it everytime it would not come on. Then I finally replaced it, its pretty easy, remove glove box and right kick panel and just try to wiggle it out.
Old Dec 1, 2005 | 05:43 PM
i try hitting it and it started working again i don't know how long it's going to last but sooner or later i would have to replace it thanks for all the help
Old Dec 3, 2005 | 02:16 AM
anyone know where the blower motor is located at ? some pics would be nice i'm trying to take it out myself and check the connection it come on sometime then shut off itself the cheapest place i check online for that part was $169 i don't wanna replace that part and find out it was just an loose connection any help would be greatly appreciated
Old Dec 3, 2005 | 05:53 AM
PLUMMAXSE's Avatar
I found the blower motor for $144 at Jerry Rome. http://www.nissandealer.com/jerry-ro..._home_page.cgi
The blower motor is behind the passenger glove box panel.
Good Luck!!
Old Jan 15, 2006 | 07:37 PM
maxima_million's Avatar
I had something very similar happen today. We have some of the coldest temps out there today. I started the car and headed inside waiting for it to warm up. I have a '98SE w/auto control temp. I got in and the engine was warm, but NO heat on ANY setting. I thought it was the blower moter but I still got nothing on 'high'. I ended up stopping the car for a few minutes (talking to a friend) and restarting the car.... voila - I have heat! I'm going to keep an eye on it and was wondering if anyone else experienced something similar???
Old Jan 16, 2006 | 04:43 AM
95gxe_vl's Avatar
everythingnissan.com or call 1-888-216-5328 ask for Joe.
They have it for $127.89.
Old Jan 16, 2006 | 05:35 AM
deeloc's Avatar
$122.77 at world parts express
http://www.parts.com/partlocator/ind...99&catalogid=1
or try a used one cheap on ebay
http://cgi.ebay.com/ebaymotors/95-96...spagenameZWDVW
http://cgi.ebay.com/ebaymotors/96-97...spagenameZWDVW
Old Jan 16, 2006 | 08:19 AM
wow - you aren't kidding...
I took a look on Ebay and found: http://cgi.ebay.com/ebaymotors/96-97...QQcmdZViewItem
since my car's blower seems to now work, I'm going hope it was a one time problem since the temp here went way down. BUT if I'm wrong, this looks like a pretty good option.
Thanks!
MattWithTheMaxima
Jun 30, 2017 01:06 PM
vingodine
45
May 21, 2016 12:46 PM
Johnny9595
Sep 3, 2015 05:18 AM
95Maxi
Aug 29, 2015 09:38 PM
kirkhilles
Aug 8, 2015 10:53 AM
