symptoms of a stretched timing chain?
Old Jan 15, 2006 | 07:14 PM
PhillyMAx's Avatar
I've been getting an annoying squeaking sound coming from my engine bay, which has been getting more frequent over the past 2 months. At first, I thought I needed to replace my struts/springs because they're shot, but I realize that I hear the same sound when my car is in "P" (park), and the engine is on. Other than the annoying squeaks, I have no driveability problems.
What are the symptoms? And I can I get this fixed?
Old Jan 15, 2006 | 07:18 PM
2 Da Max's Avatar
probably youll need to change your belts, itll give you a high pitched noise
Old Jan 15, 2006 | 07:21 PM
PhillyMAx's Avatar
i had my my belts replaced over the summer.
Old Jan 15, 2006 | 07:24 PM
njmodi's Avatar
Do I get a tax break?
You have to be more descriptive.
1. Does it squeak while turning the wheel, does it squeak in neutral, does it squeak while idling and revving the engine..
2. The belts maybe new, but they still could be loose.
Old Jan 15, 2006 | 07:26 PM
99grnmaxgxe's Avatar
It should be your serpentine belt and not timing chain.
Old Jan 15, 2006 | 08:06 PM
PhillyMAx's Avatar
Thanks for educating me on this.
My symptoms include squeaking when the car is in drive (after then engine has warmed up), and in the park. It does not squeak when I turn my steering wheel or rev the engine.
Old Jan 15, 2006 | 08:32 PM
s0ber's Avatar
Does the squeaking get louder/come on off when you have the a/c on ? Prolly your belt.
Old Jan 15, 2006 | 08:47 PM
95maxjlt
Just to narrow it down a little, if it was your timing chain, it would be a rattle. This usually occurs when the engine is still a little cold and the oil pressure has not built up. The VQ30DE is notorious for it. So, that's not your problem.
Old Jan 16, 2006 | 08:20 AM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
its your belts, not your timing chain.
the timing chain is supposed to last as long as the motor, and w/ some owners these motors have gone well beyond 200K and no problems w/ the timing chain.
mvm062
Nov 30, 2020 09:00 AM
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Oct 27, 2015 01:29 PM
intimidator
Sep 5, 2015 07:23 PM
trungg86
Sep 4, 2015 04:58 AM
