Engine Knock - VIDEO
Old Dec 2, 2005 | 05:54 AM
s0ber's Avatar
Ok, here's the deal, the car sucked up some water during hurricane Katrina and a few weeks later this noise appeared...
At first it was a faint knock, it was random, and didnt rise w/ rpms...
Recently it has upgraded to rising with rpm and being there almost all the time...
Keep in mind this is not a LOUD KNOCK, its very faint, you can only hear it if you open the hood and look for it...
All the noobs GTFO and go find a intake thread..
Here's the vid.
http://media.putfile.com/damnedknock
Old Dec 2, 2005 | 06:04 AM
MaDMvD's Avatar
I think I may be experiencing a more subtle version of this same problem. Damn Florida and its' hurricanes. Good luck
Old Dec 2, 2005 | 06:08 AM
Stephen Max's Avatar
Sorry to say, that does sound like a rod knocking. Try running some heavier weight oil, like a single viscosity 40 or even 50 weight oil. If the knock goes away then it probably is excessive bearing clearance. If it doesn't go away, it could be piston slap, but the piston slap I have heard in the past had a lighter sound than what is happening here.
Also, mechanics s***hoscopes are great for pinpointing noise sources. For instance, it is easy to tell if a noise is coming from the alternator or the AC compressor rather than the engine with a s***hoscope.
Old Dec 2, 2005 | 06:13 AM
s0ber's Avatar
I figured it was a rod, I just hope it will last a few months so I can get a new motor in there...
Old Dec 2, 2005 | 06:17 AM
s0ber's Avatar
One more thing I forgot to mention, the car wasnt reving when it sucked up the water, my step dad turned it on and it sucked up water right when he cranked it, it started for a second then turned off, so it was idling when it sucked up water.
Old Dec 2, 2005 | 08:02 AM
97maxxx's Avatar
im not an expert or anything but i second the rod-my boi had the same exact problem -we thought it was his lifters but it wound up being a bent rod? dunno its its exactly the same 4 u just giving you my 2pennies
Old Dec 2, 2005 | 10:06 AM
njmaxseltd's Avatar
That sure sounds like rod knock. It could be a wrist pin that's gone bad too.
Either or, it's time for a new bottom end.
Old Dec 2, 2005 | 10:10 AM
tavarish's Avatar
fwd gone rwd cr00
VQ35 should go in that engine bay now.
Old Dec 2, 2005 | 10:13 AM
MaDMvD's Avatar
10 carrots, and maybe some peas...
Old Dec 2, 2005 | 10:16 AM
Iron Scimitar's Avatar
Tha Snatcher
...or boosted 3.0
Old Dec 2, 2005 | 11:55 AM
s0ber's Avatar
blah, im still undecided if I wanna go the boost route or 3.5...
I was leaning towards DE-K... then 3.5... then blah to the rod..
Old Dec 2, 2005 | 12:02 PM
MDeezy's Avatar
Doesnt sound good, Rod seems like a it could be the source. Its very faint and I'm surprised you heard it, you had to be extremly close to the engine to hear it.
There is a thread in the FS parting out a DE-K, if you have time to tear your enigne apart and find the cause, you maybe able to get the replacement parts from the person parting out the DE-K. Thats if you didnt want to go the route of swapping another motor in.
Old Dec 2, 2005 | 12:13 PM
tcrow31's Avatar
sorry to say it definatly sounds like rod knock. when the car sucked up water did you change the oil??
Old Dec 2, 2005 | 12:32 PM
SDot82's Avatar
Damit I think my car is making the same sound only is softer and I can only hear it during idle. Do u all think it could be the same problem?
Old Dec 2, 2005 | 01:55 PM
90stanza's Avatar
Wouldnt know we would need a sound clip.
Old Dec 2, 2005 | 11:39 PM
SDot82's Avatar
I'll try and post one up tomorrow.
Old Dec 3, 2005 | 04:36 AM
s0ber's Avatar
Mine only did it at idle and u couldnt hear it unless you get close to it, now its upgraded to rising with rpm.. :-(
Old Dec 3, 2005 | 04:41 AM
s0ber's Avatar
Yes, oil came out looking like diareah...
Old Dec 3, 2005 | 06:11 AM
Scruit's Avatar
U wanna try me young boy?
Don't think it's a busted rod. When I drowned the engine in my Taurus the sound was there RIGHT AWAY. No delay, either weeks since the incident or minutes since startup.
It may be accelerated wear due to the oil being wrecked. As for the delay since startup it could be due to mechanical parts that expand with heat and two parts are either coming into contact or their clearance becomone too great. I'd do a couple of quick oil changes then go over it with a s***hoscope. Also try removing the belts to rule out one of the accessories as the source of the sound.
If the s***hoscope reveals the sound it coming from the bottom end then drop the oil pan and wiggle each of the rod ends. I'll wager you one small gold pig that you've spun a rod bearing due to the contaminated oil. If you HAVE spun a rod bearing then running the engine will flatten the bearing more and more and more until the bearing is wafer thin. All this time the sound will get louder and more consistent.
EDIT2: Yes, I know that dropping the aluminom upper oil pan is far from a trivial exercise... Took me about 2 hours to drop the oil pan to replace the rear main seal housing. But it would give you access to nearly all of the potential sound sources.
EDIT: Why is the tet in "Stethoscope" censored?
Old Dec 3, 2005 | 06:29 AM
s0ber's Avatar
I agree 100%, might just finally do a 3.5, put a bit thicker oil in this one to last me a few months.. Because the car was at idle when it swallowed water, if the rod was busted it would of appeared right away.
Old Dec 3, 2005 | 08:03 AM
PAREDLINE's Avatar
pull the plugs and do a compression test. While you have the plugs out pour some drygas in all the plug holes and let it dry.
In my experience, if you get water in an engine, it stops working pretty quickly.
With the motor running does the crankshaft pulley move up and down like a jackhammer? If you had a bent rod or excessive clearance it would probably transmit through the entire crank and you'd see the crankshaft pulley moving around a little.
Old Dec 3, 2005 | 08:20 AM
nismology's Avatar
If it's something like a spun rod bearing it's possible to just replace the bearing if the crank journals are fine and the rod itself isn't damaged. If not, rebuild/new motor time.
Old Dec 3, 2005 | 08:30 AM
s0ber's Avatar
Wouldnt a bent rod cause vibrations?
Old Dec 3, 2005 | 08:41 AM
nismology's Avatar
Yes. And it would cause whichever cylinder it was associated with to have a lower compression reading.
Old Dec 3, 2005 | 01:44 PM
SDot82's Avatar
Ok here is my video of what my knocking sounds like engine video, I can hear it through the whole video but certain points are around 20-24seconds, 30 second mark, and 40 seconds.
Old Dec 3, 2005 | 02:31 PM
PAREDLINE's Avatar
That sounds like a worn normal engine to me. A knock is loud. You feel pain in your bahls when you hear a motor knock. It's that bad.
You have a little ping. Sounds like your timing chain guides are starting to wear too. Maybe a little hydraulic valve noise. Its really hard to tell which it is for sure.
I'd suggest if you think it's a knock to do a compression test. I am pretty sure your compression will be fine.
Old Dec 3, 2005 | 03:29 PM
SDot82's Avatar
Thank you u made my day a lot better.
Old Dec 3, 2005 | 03:54 PM
RA030726's Avatar
I'm nutty for Nissans
i must be deaf. all i hear are the injectors. camera mics suck.
Old Dec 3, 2005 | 04:09 PM
PAREDLINE's Avatar
If you listen as he revs you'll hear a slight whirring noise. At least thats what I interpreted.
Old Dec 3, 2005 | 07:23 PM
s0ber's Avatar
on my video it says KNOCK when u can hear it
Old Dec 3, 2005 | 08:01 PM
s0ber's Avatar
btw, the knock is really loud when th e car is colder, it gets quiet that u cant berly hear it once its hot
Old Dec 3, 2005 | 09:06 PM
ThisMaxIsTight's Avatar
i dont know a whole lot about engines but dosent a bad egr system on a max make a loud noise too? .. I kinda have a noise like that from time to time, i havent done anything about it though
Old Dec 3, 2005 | 09:55 PM
DR-Max's Avatar
You didn't need to drop the upper oil pan to replace the rear main seal, I didn't when I replaced mine.
The reason why the letters "t-e-t" is sensored is because of an old member called T-E-T = Top Element Tuning, he's banned now --- forever. We'll spare you the dreadful details.
...Took me about 2 hours to drop the oil pan to replace the rear main seal housing. But it would give you access to nearly all of the potential sound sources.
...Why is the tet in "Stethoscope" censored?
ballerchris510
Sep 23, 2015 08:46 PM
ballerchris510
Sep 11, 2015 05:29 PM
TheMafia
Sep 4, 2015 08:26 AM
