everyone here with lowered max
I had to put in a straight pipe where the "S" pipe in front of the resonator used to be in order to have the resonator clear the underside. Still haven't gotten around to fixing the strut bearing on my front passenger side. Funny how turning left on a smooth I don't hear any clunking sound but on a bumpy left the noise shows up.
Eibachs and Tokicos: no problems after over 3 years.
If you are having problems bottoming out, make sure the bump stops were trimmed properly. Some people say not to trim them or just do one end of the car. Do all 4 or it will be harsh. You will be hitting the bump stops all the time. If you here any banging noises, it is due to the front upper spring cup not being in the correct position. To check this, jack up the front of the car and feel around the perch. You will find it is close to the tower at one place. To move it, you have to loosen the spring with spring compressors or the upper mount and then clock it to the right position where it doesn't rub.
sprintmax
Originally posted by SprintMax
not me.. i have problems.. still have problems.. noise.. rubbing.. bottoming out.. arg..
but when i had my H&R's and Tokico i had ZERO problems..
now i have koni/sprint
im sorry but im a little confused by your answer. if you had no toubles with your first setup, why whould you change it??
also, for people reporting no problems ever, it would be great if you say what setup you had and how long you have had it for. thanks a lot.
Re: sooo
Originally posted by Maximus98
would the sprints be a bad idea? I am looking into the KYB AGX struts and shocks with either the weapon r coilovers or the Sprints.
I have just Eibachs right now, and I will be putting in the KYB AGXs as soon as they come in.
I also haven't had any problems lowering my car either.
Re: sprintmax
First car was totalled.. had no spare setup.. Ins company took that with them..
Loren... thanks for the heads up.. i am going to try that this weekend.. since i havn't gotten an alignment since i pulld it down saturday
Koni and H&R's No problems!
Once again thanks to "Ryz" he helped greatly with my suspension installation. No knocking, no groaning, no rubbing, just more smiles per mile. The downside to this setup is that the car really doesn't look lowered. I have 17" SE wheels and most people dont even noticed that its lowered. Boooo hooooo j/k. But I'm really loving Koni's. Just yesterday I increased the stiffness on the front to two full turns from softest.
I'm loving every mile of it, and I would suggest these struts to anyone in the market for a suspension uprgrade. They're great on the highway and pretty good on bad roads. Although bad roads will always be bad roads, and I dont know anything about Tokico's or KYB's but I know I love my current setup. Now only if H&R made a spring that was a 1.75 drop in front and 1.6 drop in the back. Now that would be sweet. (I think I have an email to send.... "Dear H&R...")
I have the Stock/Intrax setup and it is ok no problems yet knock on wood.
Originally posted by GTRBlkMax97
So what does that sound like? I think i may have the same problem.
You mean when I do a left turn? It sounds like a clunking sound but I better check to see if the CV boot is ok as well. This only happens when I'm doing a left turn over a bumpy road. Right turns round are fine, however. This was discussed a while back when someone else found the same symptoms. I've noticed that with the Konis I can hear a tick-like noise when I backup the car and then move forward again. I always thought that the Konis were moving around within the strut housing.
ok so whats the deal here
some people are having no problems while others have obviously had some. so what is this like a "luck of the draw kind of deal". some sh*t works for some people but not for others? does this sound about right?
Correct me if I am wrong.....
Intrax-2"or more drop
Sprint-1.5" or more drop
H&R-1-1.5" drop with a stock ride
Eibach-1-1.5" drop with a stiffer ride
I want mine firm with a nominal drop. Am I looking at sprints here? I have 18" rims. Will Eibach lower it enough? H&R with KYB sounds good.
I am gunna order the KYB AGX's shocks and struts.
Re: Correct me if I am wrong.....
Re: Re: Correct me if I am wrong.....
Originally posted by Ravq
The Intrax are supposed to be 1.75" but I'm not sure about the rest.
Re: Re: Re: Correct me if I am wrong.....
My intrax dropped it about 2" or so. they make the car sit really low, at first I wasn't used to it and I most of the time fell into the seat because I thought it would be higher up, but I got used to it and I really love how snappy the rear is around corners, and stability of the car is great, going around corners having no body roll at all is wonderful
eibach\tokico. no major problems, i bought it them used and they are getting softer. when i first got them, it was great, but with more driving in sf's focked up roads-the ride is getting bouncier. the drop isnt too much, i like it a lot compared to the stock height. if i had a chance i would probably try the eibach and koni set up. its stiffer. but if you like to just cruise i would get the h&r with koni shocks. i would stay away from the cheap coilovers.
Intrax = 1.75"
Sprint = 2"
H&R = 1.5f / 1.4r
Eibach = 1.5"
Sprint = 2"
H&R = 1.5f / 1.4r
Eibach = 1.5"
so what about suspension technique springs ? i have not heard about them in a while .
I have progress technology springs the ride is ok definatly not harsh ,I have had 0 problems .the drop is 1.7 fr 1.5 rr looks real even the front has settled tremendously & now I think I am sporting a 2" drop ,my koni's keep every thing under control.
Sweet.....
they are mine then. Are the KYB strut and shock mounts necessary? I am gunna call TireRack tomorrow morning and place the order. Someone send me an email where I can get the lowest price on Sprints. RedLX92@aol.com
Thanx guys. You've made owning my Maxima the best yet. I just bought it 45 days ago, and I LOVE IT!
I have Cattman coilovers now and they're...not bad....The reason why I din't say that they're good is because the rear coilovers' strut rods snapped twice. When I had the eibach's, the ride was terrible. I just couldn't figure why the ride changed so much just by dropping the car only about 1 inch. I just wish someone could figure out a way to let you drop an car and still keep a comfortable ride
how many of you have had NO problems after lowering your cars. NO = none, zero, zip, nada.
ok pplzzz
