Help: Pressure Plate install
Old Dec 2, 2005 | 01:57 PM
1991tsi's Avatar
My pressure plate doesn't seem to fit all the way over the 3 studs in the flywheel. It fits onto them, enough to hold itself in place, but there is distance between it and the flywheel.
Should it fit snugly, or should the pressure plate bolts pull it into position? Any experienced help would be appreciated!
Old Dec 2, 2005 | 02:11 PM
Nismo3112's Avatar
Custom User Title
It will be flush once you tighten the bolts.
i30ds's Avatar
Armed and Dangerous
There should not be any space between the pressure plate and the flywheel. The holes and the dowl pins are supposed to be a really tight fit. Just get it on as good as you can by hand and then as you tighten up the bolts it will bring the pressure plate down on the flywheel.
Old Dec 2, 2005 | 03:15 PM
1991tsi's Avatar
thanks a lot, guys. I can always count on org'ers to provide answers in about the time it takes to eat dinner... now back to the garage...
Old Dec 2, 2005 | 10:09 PM
ThurzNite's Avatar
I snapped this pic from under. Lays flat on mine.
Jae
Old Dec 3, 2005 | 09:05 PM
i30ds's Avatar
Armed and Dangerous
Anytime.
10char
Old Dec 4, 2005 | 11:57 AM
1991tsi's Avatar
Help needed: Clutch Parts
Whelp, hours of labor and my clutch setup doesn't work. Theres a weak grinding noise when I try to put in in gear with car running, regardless of where the clutch pedal is, and it WILL go into gear, but won't send any power to the wheels. Seems as tho the PP and clutch disc aren't interacting, or the input shaft and disc aren't interacting. I've used the following parts from Pinnacle Nissan:
4th gen disc 30100-40U14
5th gen PP 30210-89F00
TO Bearing 30502-41U20
lowpost99
Oct 26, 2025 06:53 PM
matts95max
Apr 23, 2025 10:44 AM
MaxLife17
Jun 27, 2019 01:37 PM
BkGreen97
Apr 2, 2016 05:47 AM
Johnny9595
Sep 3, 2015 05:18 AM
