Need help with Airbag light
Old Dec 3, 2005 | 02:28 AM
Noslen's Avatar
For some reason the light now flashes when the car is running. How do i get rid of it?
Peace
Old Dec 3, 2005 | 03:39 AM
aussie983's Avatar
How to reset SRS(air bag) light
Open the driver's door. Note the rubber covered button located low on the B pillar, a button which is pressed by the door when the door is closed. This is the Driver's Door Switch (DDS).
Turn the ignition from OFF to ON. Press the DDS at least 5 times within 7 seconds after turning the ignition switch ON. Turn the ignition OFF. Close the driver's door. Start the engine.
If the airbag warning lamp is still on (or still flashing), there is a fault in the Supplemental Restraint System which must be diagnosed and repaired. This is a job for your local friendly Nissan dealer.
Old Dec 4, 2005 | 12:10 AM
Noslen's Avatar
I followed your instructions and now it flashes in a 'code'.
Old Dec 4, 2005 | 07:40 PM
aussie983's Avatar
Then you probably want to get it checked out by the dealer???
Old Dec 4, 2005 | 09:23 PM
aussie983's Avatar
Just found this, but i dont know if it will be any help. You could try finding which sensor is faulty and replacing it yourself.
Number of Flashes - Reason
1 Left front actuator solenoid circuit
2 Right front actuator solenoid circuit
3 Right rear actuator solenoid circuit
4 Left rear actuator solenoid circuit
5 Left front wheel sensor circuit
6 Right front wheel sensor circuit
7 Right rear wheel sensor circuit
8 Left rear wheel sensor circuit
9 Motor and motor relay
10 Solenoid valve relay
16 Control unit
None, but dashboard light on Power supply or ground for control unit
Old Dec 7, 2005 | 09:13 AM
Noslen's Avatar
i don't wanna go to the dealer, they're gonna rape me with charges. Can i go to my local shop?
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
Colossus
Sep 9, 2015 05:46 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
