EGR temp sensor...
Old Dec 3, 2005 | 07:30 PM
cefiro8701's Avatar
EGR temp sensor...
CEL came on...took code and got EGR temp sensor...
0305.
thats the only code...car feels and starts fine...
i installed an oil catch tank recently and i see white stuff in the tubes...could that have anything to do with it???
any help is appreciated
Old Dec 4, 2005 | 06:08 AM
cefiro8701's Avatar
anyone please!
Old Dec 4, 2005 | 09:31 AM
knight71's Avatar
0305.
Maybe this will help:
http://photobucket.com/albums/v158/e...s_location.jpg
Old Dec 5, 2005 | 08:54 PM
cefiro8701's Avatar
i asked my coworker..he said an 0305 is a misfire in cyl 5...
i thought the flashes were the same as the scanner codes...thank God i was wrong...
Old Dec 5, 2005 | 09:59 PM
1FSTMAX's Avatar
first of it could be carbon build up thats causing the egr temp sensor to trip the ecu. It can also be a bad temp sensor. I'd replace it. Also why on earth would you need a catch can for? And how's the vq35 swap going?
Old Dec 6, 2005 | 07:34 AM
naplesmaxima aka Tommyali the scammer!'s Avatar
I scam therefore I am
its a 12mm wrench to take it off use tb cleaner to clean it off
Old Dec 6, 2005 | 11:46 AM
njmodi's Avatar
Do I get a tax break?
Did you get P0305 or DTC 0305 - if you got the code via the blinking CEL method, then its DTC 0305 = EGR temp sensor, if you got it via an OBD II scan tool then its P0305 = Cylinder 5 misfire
Old Dec 6, 2005 | 07:32 PM
cefiro8701's Avatar
i got 0305 with the blinking CEL...it cant be DTC 0305 cause my CEL would have to blink continuously.
also...would the tb cleaner work??i just spend 90 bucks on an EGR temp sensor..
what would happen if i didnt change it??maybe if i changed it later on?
Old Dec 7, 2005 | 08:59 AM
njmodi's Avatar
Not sure what you mean by that?
If you got 0304 via the blinking CEL/ECU screw method, then its a badEGR temp sensor code. It could be a clogged EGR tube, but I would suspect the sensor itself is bad. It's cheap (but not easy) to try clean out the EGR passages first, and if that doesn't work, it's time to replace the sensor.
Old Dec 7, 2005 | 09:02 AM
njmaxseltd's Avatar
Old Dec 7, 2005 | 11:48 AM
cefiro8701's Avatar
0304 isnt that a ks?
i got o305.which is an EGR temp sensor...but i have a feeling that has nothing to do with it.
i think the catch tank is screwing with it...the EGR tubes are flexing way too much and is not letting air in the intake manifold...i gotta replace that now.
Old Dec 7, 2005 | 11:49 AM
njmodi's Avatar
my bad - I meant 0305 - which is what you pulled...
Old Dec 8, 2005 | 09:09 AM
cefiro8701's Avatar
yeah...definitely not enough oxygen going through my egr...the hose i use is flexing in ugly ugly ways.
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
msellas
Sep 23, 2015 09:16 PM
bumpypickle
Sep 20, 2015 08:22 AM
bumpypickle
Sep 19, 2015 01:07 AM
