it dont start.
Old Dec 5, 2005 | 01:57 PM
AlexJones's Avatar
it dont start.
Problem: car wouldnt start, replaced battery, still wont start. all accessories work. it was more reluctant to start prgressively over the last few days. is my starter dead?
Old Dec 5, 2005 | 02:06 PM
bkea's Avatar
Youngster, you need to check back through the previous posts. This comes up about every three or four days. Chances are real good that it is the ignition switch (not the keyed switch) which is located inside the plastic housing around the steering column. If its not that, then it likely is the starter.
Old Dec 5, 2005 | 02:34 PM
NmexMAX's Avatar
dot dot dot ...
Originally Posted by AlexJones
is my starter dead?
Take it to AutoZone so they can test it and tell you the answer to this.
Since you say
that would rule out grand dads suggestion here -->
Old Dec 5, 2005 | 02:46 PM
AlexJones's Avatar
ya, i know its not the ignition switch, i turn it clicks, and i had it replaced about 6 months ago.
Old Dec 5, 2005 | 02:53 PM
NmexMAX's Avatar
dot dot dot ...
What did you replace 6 months ago? Ign switch or starter?
Old Dec 5, 2005 | 03:35 PM
realtime's Avatar
Posted to a new thread.
Old Dec 6, 2005 | 02:05 PM
bkea's Avatar
Originally Posted by NmexMAX
Since you say that would rule out grand dads suggestion here -->
Nope, mine got progressively worse over a fairly long period of time.
Old Dec 6, 2005 | 02:10 PM
CreativeDesignz's Avatar
LOL if the car doesnt start how will he take it to autozone?
Old Dec 6, 2005 | 02:24 PM
NmexMAX's Avatar
dot dot dot ...
Use another car... typically that's what common sense would point to.
Old Jan 17, 2006 | 03:05 PM
IlyaK's Avatar
The Golden One
Dude...NmexMax....your so harsh...but hilarious at the same time.
To the guy before this...I took mine out...hopped in my moms subaru...and went to Advanced Auto Parts...got it tested...got my answer....went back outside....sat in the car....turned the key....started the engine....went home...got out of the car...installed all parts back onto the car....and...and...should I keep going?
"If 90 percent of the world doesn't have it, why do they call it common sense?"
msellas
Sep 23, 2015 09:16 PM
97_GXE
Sep 15, 2015 06:47 AM
rnb754
Sep 14, 2015 11:39 PM
