Vibrating while driving
Old Dec 6, 2005 | 03:41 PM
NCSUpilot's Avatar
I just had my car aligned and wheels balanced. Now there is a vibrating when I drive (light vibrating that I can feel in the pedal and also in the floor board. I can hear it also, sounds like a hum. It changes with speed and goes away if I hold the steering wheel dead center, but as soon as I turn the wheel slightly to the left or right it vibrates. Also, as soon as I apply the brakes from highway speeds, it subsides. Any thoughts? Thanks!
Old Dec 6, 2005 | 03:45 PM
kormax97
Check and see if there's any problem with the axle. I had vibrations when my boot was torn.
Old Dec 6, 2005 | 03:48 PM
matty's Avatar
Make sure they tightened all your lug nuts enough. I put on my right wheel not all the way tight one time and a week or two down the road they loosened up just enouhg to cause a vibration and i thought my tranny was dieing.
-matt
Old Dec 6, 2005 | 04:34 PM
dizheafta's Avatar
could be a wheel bearing or warped rotors
Old Dec 7, 2005 | 06:30 AM
varyouga's Avatar
99% that it's a bearing. I had the same exact symptoms and problem.
Should be around $200 to replace. I got the same price at the stealership as local garages so I just did it there.
Old Dec 7, 2005 | 11:03 AM
NCSUpilot's Avatar
-matt
Check these, they were all tight. Also, I only had 4 on one wheel because of a cross threaded one. I put it back on there tight,maybe that will help.
Also, I replaced the passenger front wheel bearing a few months ago, the problem I am having this time is quite different from what I experienced before. but I guess the symptons could be different. Ill keep my eye on it. Thanks.
Old Dec 7, 2005 | 11:10 AM
MDeezy's Avatar
Did you get a print out of your alignment specs? They could have "aligned the car" but its still out of factory spec.
Old Dec 9, 2005 | 09:47 AM
NCSUpilot's Avatar
I think that is the problem. I had it aligned, but the front left camber is at 0.8, which is just into the red. The only way to fix is new struts, that's what I was told. I ran into a ditch a few weeks ago, which i assume bent the strut. I bend the control arm, and the tie rod. I replaced the control arm and straightened the tie rod, so it must be the strut that is off still...Guess I'll have to live with the vibration till I get new struts...
Old Dec 9, 2005 | 09:45 PM
19maxima97's Avatar
did you lower it? i had same problem with lowered car... i alligned it and balanced it but forgot to get a camber kit... after i got camber kit, it went away...
Old Dec 10, 2005 | 01:12 PM
NCSUpilot's Avatar
nope, everything is stock. They put a camber kit on it to make it better, but it is still out of spec. So that is probably what is causing the vibrating.
Old Dec 10, 2005 | 01:25 PM
99SEL4ME's Avatar
If you're getting a vibration up here in the Northeast, it's probably snow stuck in the spokes of your wheels. Last year when I was leaving work in the midst of a snowstorm, I had to drive through a small snowbank to get out. I started driving on the road, and my steering wheel was vibrating. I pulled over and saw that my front wheels were caked with snow. I put my hand in and pulled the snow out....... vibration gone. The snow was obviously throwing my wheels off balance.
Old Dec 12, 2005 | 04:09 PM
NCSUpilot's Avatar
I wish I had snow down here in Raleigh, NC. I miss the snow! Grew up in Minnesota.
Old Dec 12, 2005 | 04:23 PM
descent's Avatar
i have heard extra road noise coming from my tires since i put on the z rims/tires. i havent really minded...should i? anything cheap that will correct it or is this the price i pay for getting different rims?
Old Dec 12, 2005 | 04:28 PM
Digital's Avatar
VIP
Bearings, all day.
Old Dec 12, 2005 | 06:08 PM
bravehart's Avatar
Courtesy Nissan just quoted me $400 per side to replace wheel bearings???
Old Dec 12, 2005 | 06:45 PM
MDeezy's Avatar
Wow I had wheel bearing replaced on my brothers max, driver side with alignment for $260.
Is that the price for the wheel bearing or the whole hub?
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
alahjahwan09
18
Sep 21, 2015 09:12 PM
Bonka
Sep 14, 2015 11:18 PM
thenewguyy
Sep 12, 2015 11:12 AM
