little low end power...why?!?!
Old Dec 8, 2005 | 07:07 AM
jvelos3's Avatar
yeah ive been wondering why my max has little low end power. Anything under 2300rpms suck. I dont have problems with middle or high end. I actually feel a sort of boost once i hit 2700rpm. Can anyone help me out with this? Is this normal?
Old Dec 8, 2005 | 07:18 AM
MaDMvD's Avatar
Yes, I have a GLE as well and that's just how it is. Between ~2700 - ~3700 you will feel that huge pull, then it starts dropping down again. Got my 00VI though, so not for long!
Old Dec 8, 2005 | 07:21 AM
tavarish's Avatar
fwd gone rwd cr00
knock sensor, or automatic transmission
When my car was auto, i had no problem breaking the tires loose if I floored it from a stop, but when my knock sensor went bad, it was like a neutered dog. NO power anywhere.
Old Dec 8, 2005 | 07:26 AM
Maverick7687's Avatar
I cant begin to tell you what it is but I don't think its normal. I can shift at about 2500 and still have pretty good pick-up.
Knock sensor, fuel filter, O2 sensor(s), spark plugs, dirty injectors, dirty air filter. Just some things off the top of my head that MIGHT cause this.
Mav
Old Dec 8, 2005 | 09:52 AM
nart86
sorry to hijack ur thread, but how'd u know if u have a bad knock sensor ?( other than having a huge loss in power).
thanks
Old Dec 8, 2005 | 10:03 AM
NmexMAX's Avatar
dot dot dot ...
thanks
http://www.forums.maxima.org/showthread.php?t=104931
And...
http://forums.maxima.org/showpost.ph...&postcount=341
Old Dec 8, 2005 | 10:07 AM
99grnmaxgxe's Avatar
The low-end gets worse if you have an aftermarket intake.
Old Dec 8, 2005 | 10:11 AM
NmexMAX's Avatar
dot dot dot ...
I've heard the VQ35DE TSB works best
Old Dec 8, 2005 | 02:08 PM
pinoy87's Avatar
yes i do have an auto.
I have already changed fuel filter, spark plugs, cleaned injectors, and i have a new cone filter.
Unfortunately I bought the car with a injen cai...i have since changed it into a short ram. I do not have the stock air box and scoop.
correct me if im wrong but i thought that o2 sensors only affect power during WOT. also ive never heard any knocking but I do get a code sometimes...then i reset it and periodically check it...doesnt come back right away but does eventually. Does this mean im getting knocks or my knock sensor is fudged.
also if it is my o2 sensors...do i have to get new ones or can i just clean them with some denatured alcohol or something?
Old Dec 8, 2005 | 02:13 PM
pinoy87's Avatar
oops..this is JVELOS3 im logged in my old screen name that i have since changed...sorry for the confusion.
Old Dec 8, 2005 | 02:25 PM
NmexMAX's Avatar
dot dot dot ...
2 accounts?
Old Dec 8, 2005 | 02:28 PM
jvelos3's Avatar
i had the pinoy87 but forgot the password and now im on my friends laptop in school which had the password saved and I did not realize it logged me in as pinoy87 automatically.
Old Dec 8, 2005 | 02:29 PM
NmexMAX's Avatar
dot dot dot ...
Ever try getting the password emailed to you, Hint: Click on forgot password option during log-in
Old Dec 8, 2005 | 02:39 PM
jvelos3's Avatar
well this was about the time i got my school email so i just was *** it ill just make a new one going to my school email
Old Dec 8, 2005 | 06:19 PM
njmaxseltd's Avatar
There's your problem. The Injen is the absolute worst intake available for our cars, especially if your an auto tranny. Good thing you took it out, but your short ram isn't helping you that much. Try to locate a stock intake and put it back on the car. You will feel much better pull in the lower RPM range.
Old Dec 8, 2005 | 07:29 PM
jvelos3's Avatar
how about the place racing cai? how do those do? If theyre good then ill just order the ones from ebay. I would like to get the stock airbox but I dont feel like going to a junk yard in this weather.
Old Dec 8, 2005 | 07:53 PM
Tatanko's Avatar
Bacon Lover
Any aftermarket intake on the auto will cause the lag. Switching aftermarket setups won't help much.
Old Dec 8, 2005 | 07:58 PM
themills's Avatar
A Real CAI, should not decrease low end at all on a 5speed. But on auto, I dunno, wouldnt ever own any auto car...
Old Dec 8, 2005 | 08:22 PM
chilled's Avatar
Actually, since none of the guru's have quoted this yet I will.
The whole reason the stock intake is better than any of the others is because of the resonator between the accordian hose and the MAF. It slows the air charge down enough for the air/fuel mixture to atomize more efficiently, thus creating more low end torque.
Old Dec 8, 2005 | 08:29 PM
themills's Avatar
Do you have a link to where that was originally discussed? It seems that 50 degree cooler air would at least help some? Not saying your wrong, I just want more evidence
Old Dec 8, 2005 | 08:44 PM
jvelos3's Avatar
resonator?? Is this the square looking thing that the hoses connect to? If so I already am using that in my short ram. I went to the junk yard like 3 months ago.
Old Dec 9, 2005 | 05:06 AM
lilaclucymaxima's Avatar
Team Ramrod
Yes. It's the square looking thing before your MAF sensor.
Old Dec 9, 2005 | 05:42 AM
Pieps's Avatar
So if I have a short ram intake w/ cone filter, and have the resonator, am i still losing low end torque? It really doesn't feel like it.
Old Dec 9, 2005 | 08:15 AM
chilled's Avatar
Some argue whether its better to use the stock box, the stock box hacked, or the cone filter- I personally like the cone.
Old Dec 9, 2005 | 09:32 AM
MaximaSE96's Avatar
Maxima Owner
helmholtz was a smart guy...and so was nissan for using his design
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
lrb6805
Sep 30, 2015 08:12 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
