cold start up problem.computer reset?
Old Dec 8, 2005 | 03:22 PM
s600ergy's Avatar
i started having very bed start up problems when it gets cold but not all the time some times. why?
i hed that problem befor,that was a computer reset problem,after i did reset at nissan, problem was gone.that was like 2 years ago.
i did that at 110.000ml now its 128.000ml
my spark plugs r 6 years old but i have only 28.000 ml on them.
allot of ppl telling me its bed spark pluggs i should chenge them. is it the case?
Old Dec 8, 2005 | 03:25 PM
NmexMAX's Avatar
dot dot dot ...
Do you have any CEL codes?
Starting = spark + fuel.
Old Dec 8, 2005 | 03:28 PM
s600ergy's Avatar
no nothing,no cel light.
Old Dec 8, 2005 | 03:30 PM
NmexMAX's Avatar
dot dot dot ...
Try changing the plugs then ...
Old Dec 8, 2005 | 06:12 PM
Business810's Avatar
One other suggestion... make sure that the self-diagnosis screw on the ECU is turned all the way off (I forget whether it's clockwise or counterclockwise off the top of my head). One time when I checked codes I didn't turn the screw quite all the way back and it didn't like cold starting - it would idle really low and sometimes stall when cold. Fixing where the screw pointed solved the problem for me.
If that doesn't solve it, then I'd agree with Nmex and say change the plugs.
Old Dec 8, 2005 | 06:15 PM
njmaxseltd's Avatar
Originally Posted by s600ergy
i started having very bed start up problems when it gets cold but not all the time some times. ......... i hed that problem befor,that was a computer reset problem,after i did reset at nissan, problem was gone.
There is no such thing as a computer reset. You can clear error codes, and so can Nissan. Clearing error codes has absolutely nothing to do with operational parameters stored in your cars ECU. This information can be found in the factory service manual.
Please describe your cold start problems a bit more so we can try to help you better.
Old Dec 8, 2005 | 06:16 PM
happyricefob's Avatar
V^___^V
i have the same problem, but it was all fixed when i changed my spark plugs.
i suggest changing your sparks... it takes around 1 hour and cost about $60 for all 6 sparks i believe...
Old Dec 9, 2005 | 07:11 AM
kenscivic's Avatar
try turning your key to the on position to let your fuel pump get a head start
give it about 5 seconds and then try starting it maybe?
ballerchris510
Sep 23, 2015 08:46 PM
QueensMAX
Sep 15, 2015 04:14 AM
Colossus
Sep 9, 2015 05:46 AM
trungg86
Sep 4, 2015 04:58 AM
