Engine gets powr but wont start.
Old Dec 13, 2005 | 02:32 PM
Goldie's Avatar
Sup All,
Okay its kind warm like 77 here so freeze starter trouble is out.But anyway My car was park under the carport, I didnt leave the door open trunk etc, I got in pushed clutch to floor, as usual and nothing,but a undescribable annoying noise. The engine powers but wont turn over at all. Service engine light came on.Batterys terminals are good and secure no corrosion. What else could it be?
Thanks In Advanced,
Goldie & Shawty
Old Dec 13, 2005 | 02:36 PM
NmexMAX's Avatar
dot dot dot ...
Check the farkin codes shawty... y0!
Old Dec 13, 2005 | 02:38 PM
moogotzskillz2's Avatar
what kinda sound? like clicking, or wining?
Old Dec 13, 2005 | 02:40 PM
Goldie's Avatar
Dont know what that is.
The sound is a whine like sound the more I turn the key the more in continues
Old Dec 13, 2005 | 02:44 PM
NmexMAX's Avatar
dot dot dot ...
Check the f'ucking ECU codes is what I really meant.
http://www.forums.maxima.org/showthread.php?t=104931
Old Dec 13, 2005 | 02:45 PM
it might be ur starter, try knockin it wit a hammer? and try.
Old Dec 13, 2005 | 02:47 PM
Goldie's Avatar
where is my starer Guys I am not car savvy gas tune ups and oil changes with blad changes when told I am so lost
Old Dec 13, 2005 | 02:50 PM
search the "how to's" to see pics. but its right UNDER ur throttle body. remove the air box assemble. and you will see it..
right Nmexmax?
Old Dec 13, 2005 | 02:53 PM
NmexMAX's Avatar
dot dot dot ...
Courtesy of
http://www.motorvate.ca/mvp.php/516
Old Dec 13, 2005 | 03:01 PM
thankz,
Nemexmax
Old Dec 13, 2005 | 03:29 PM
Goldie's Avatar
thank guys I don't know what it is but thanks anyway
Old Dec 13, 2005 | 03:44 PM
NmexMAX's Avatar
dot dot dot ...
If this happens..
Click on this----->http://www.forums.maxima.org/showthread.php?t=104931
Old Dec 13, 2005 | 04:56 PM
cefiro8701's Avatar
just had that same problem...its your battery...just get jumper cables and it'll start right up.
Old Dec 13, 2005 | 10:08 PM
2 Da Max's Avatar
thankz,
Nemexmax
dont thank him he knows nothing
lol jk
Old Dec 13, 2005 | 10:12 PM
NmexMAX's Avatar
dot dot dot ...
... I would almost certainly rule your(cefiro8701) thought out ... but it could be.
Swap batteries with another car if you've got one.
Old Dec 13, 2005 | 10:41 PM
cefiro8701's Avatar
well...my engine was turning over just fine...and everything was working...but all i really need was a jump.
like...i know it sounds wierd...but the engine WAS turning and all the electronics worked perfectly.until i tried to start the car.me and steven88 solved the problem with jumper cables.
Old Dec 13, 2005 | 10:44 PM
NmexMAX's Avatar
dot dot dot ...
When my batteries die, it will do what you said all elec work etc, but when the key is turned to crank, be dead like this ---->
Old Dec 13, 2005 | 11:53 PM
cefiro8701's Avatar
thats cute.
Old Dec 14, 2005 | 06:14 PM
Goldie's Avatar
hey guys can anyone recommend an AM starter I bought a ULTIMA REMANUFACTURED starter from Oreily's
Goldie's Avatar
oh yeah I tried the jumper cables trick nothing happenee but the whining sound.
Old Dec 14, 2005 | 06:16 PM
NmexMAX's Avatar
dot dot dot ...
If it has a warranty why the f'uck not.
Reman parts are just like the luck of the draw though.
Old Dec 14, 2005 | 06:44 PM
Goldie's Avatar
autozones came 211.08 with tax minus 40 for the old one oreiley's was 162.36 minus 40. The one from autozone was broken at the two screws and the one from oreileys is perfect. both with a warranty Does anyone know how to install it? FYI I looked in how to 4ths and it said how to top the noise not how to replace it
Old Dec 14, 2005 | 06:48 PM
NmexMAX's Avatar
dot dot dot ...
2 bolts, 1 wiring connection.
Common sense, pop your hood when you gt a chance and take a look, shouldn't take you more than 45 minutes, if it's your firs time.
I can do mine in less than 15 since I do not have my stock intake plumbing in place....
Old Dec 14, 2005 | 06:49 PM
Goldie's Avatar
What does that mean?
Old Dec 14, 2005 | 06:53 PM
NmexMAX's Avatar
dot dot dot ...
"Well, they can't all be winners can they?"
Old Dec 14, 2005 | 07:00 PM
MaximaSE96's Avatar
Maxima Owner
i beg to differ...thats the whole purpose of reman parts...to make broke or warn out ones work again
Old Dec 14, 2005 | 07:09 PM
NmexMAX's Avatar
dot dot dot ...
http://www.forums.maxima.org/showpos...91&postcount=4
http://www.forums.maxima.org/showthread.php?t=444982
... ... ... Differ all you want I don't care.
James92SE
142
Jan 2, 2024 09:23 AM
Socalstillen
Sep 20, 2015 11:46 PM
97_GXE
Sep 15, 2015 06:47 AM
rnb754
Sep 14, 2015 11:39 PM
