Car acting wierd...
Old Dec 17, 2005 | 10:29 PM
jdrvr18's Avatar
Car acting wierd...
Ok, today i filled my car up with gas and about 5min later it started studdering. Well when i finally got it home, i thought that maybe it was the fuel filter so i changed it and it still does it. It wont even idle right, you can watch the rpm guage jump up and down, and when you drive it, it does runs really ruff. Also i did have that timing chain rattle for quite some time now, im just wondering if maybe it has finally gone bad or something. I dont know what it could be...Oh yea theres no water in the oil either...Anyone know?
Old Dec 17, 2005 | 11:02 PM
Sharp's Avatar
sounds to me like water in the gas..but i dunno...
Old Dec 17, 2005 | 11:46 PM
jdrvr18's Avatar
So, should i buy some gas treatment and try it?
Old Dec 17, 2005 | 11:51 PM
the_3d_man's Avatar
siphon the gas out into a container and put new gas in. (if that doesn't help pour the old gas back in!) gas treatment isn't going to help much if you got bad gas.
Old Dec 18, 2005 | 12:07 AM
jdrvr18's Avatar
OK, well i guess ill have to try that, also i was wondering, could it be like a bad spark plug or something like that? You dont think it has anything to do with the timing chain, correct?
Old Dec 18, 2005 | 12:11 AM
the_3d_man's Avatar
... timing chain... unlikely... bad coil pack is not out of the question but like you said it started right after filling up... so just start by trying some new gas. I've gotten bad gas before. (really stank up the room...)
Old Dec 18, 2005 | 06:07 AM
njmaxseltd's Avatar
I don't believe the bad gas theory.
Is you CEL light on? See if the ECU has any error codes stored.
A hunting idle speed points to a defective TPS sensor.
Old Dec 18, 2005 | 10:11 AM
jdrvr18's Avatar
No lights are on, but see it runs really bad when driving it too not just at idle.
Old Dec 18, 2005 | 01:45 PM
Lyndon5's Avatar
Two summers past drove my 95 to Colorado. Decided to top off the tank (I use only premium) at a Shell station before going into the mountains. Started noting some missing, and by the time I drove the 40 miles to the condo, I could barely make it up the drive. New fuel filter did not help, so poured in a can of water removing fuel treatment before retiring for the evening. Stumbled a couple of times the next morning when I started it, then cleared up and has not missed since. Water in gas does happen..
Old Dec 24, 2005 | 09:28 PM
jdrvr18's Avatar
Ok, well its still doing it...something i noticed was it doesnt really start acting up until it is warmed up some. You can also get it up to speed and it will run steady, but once you try to give it gas it will start runnin ruff and when you come to a stop it will die most of the time. anyone know what else it could be?
Old Dec 30, 2005 | 01:28 AM
knuckles2's Avatar
Im having the same problem... Can you tell me what caused this? thanks
Old Dec 30, 2005 | 08:22 AM
nismos14's Avatar
§è~® f®ÈÄk
Sounds like a problem with your maf.
Old Jan 1, 2006 | 11:53 AM
tengunsalute's Avatar
I think your ignition coils may be misfiring. My '99 max is doing the same. I'm looking to replace all my 6 coils
Old Jan 1, 2006 | 12:52 PM
descent's Avatar
my 86 ford van does this as well...with the studdering and it eventually stalls out. its been sitting on the street for the past 2 years. i wuold like to know if there's any fix. ive done all the obvious stuff, fuel filter, spark plugs, and what not. im really curious as to what is wrong here.
Old Jan 2, 2006 | 09:25 PM
jdrvr18's Avatar
Well i checked my coil packs and they all seemed good for me. So i guess im just gonna drain my gas tank and refil it and see if that helps any and change the spark plugs...
Old Jan 10, 2006 | 11:52 PM
jdrvr18's Avatar
Ok, new gas didnt work. So i took it down to Autozone and they pulled a code that said my Crankshaft sensor was bad, so i replaced that and the car is still messin up. Im runnin out of things to do...
Old Jan 11, 2006 | 05:09 AM
r_stevenson's Avatar
Hello All,
New to the forum. Great sight. I have a '96 Maxima with 165k miles. I have touble starting the car in the cold. Is it time to change the coil packs, or do they last forever? Also, should I think about changing the timing chain?
Many Thanks,
Russell
Old Jan 11, 2006 | 10:42 AM
19maxima95's Avatar
It's your maf, I had the same symptoms and I changed everything but the maf. Once I change the maf, all the problems went away.
Old Jan 11, 2006 | 02:16 PM
95GLEPEARL's Avatar
Ok heard this a million times, my also does this, but my doesn't die. Have replaced everything mentioned above and then some, I am now on to the thought that it could be a vacuum leak. Oh and noone else has ever fixed it.
Old Jan 11, 2006 | 03:53 PM
The Deal's Avatar
You better believe the bad gas theory. Its all over the local news how a Valero had water in its tanks. Cars werent starting after a fill up and many cars werent making it far from the gas station. Its very possible that there is water in you tank, escpecially with no prior symptoms and having it occur right after fill up.
Old Jan 11, 2006 | 11:20 PM
jdrvr18's Avatar
is there a place on here that explains on how to reaplace you MAF?
Old Jan 12, 2006 | 09:41 PM
jdrvr18's Avatar
could anyone tell me how to replace my MAF or how to clean it and like where its located?
Old Jan 13, 2006 | 05:40 AM
Ridge Runner's Avatar
When you said new gas didn't help, did you drain the tank and then refill, or just add gas?
Also, I have had similar symptoms when a spark plug wire went bad.
Old Jan 13, 2006 | 12:51 PM
jdrvr18's Avatar
well i just put new in after i got it down to about 1/4 because i couldnt find a way to drain it out...
Old Jan 13, 2006 | 06:39 PM
mastajonjon's Avatar
Yup...I had the same problem...its the MAF sensor. After I replaced it, it still had some problems with studdering...then I replaced my o2 sensor...car runs fine now. Just go to the "do it yourself" section of this forum and follow the easy steps...u can buy a maf on ebay for around $100 or less...
Old Jan 14, 2006 | 12:16 PM
jdrvr18's Avatar
well see i took it to autozone because my check engine light just came on and it came back with a bad crankshaft sensor and vibration sensor, well i replaced the crankshaft sensor and that made no difference.
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
homewrecker
Aug 24, 2015 08:56 PM
Balkins
Aug 12, 2015 06:39 AM
