Clutch master or slave???
Old Dec 18, 2005 | 08:03 PM
kashman15's Avatar
just got a new 5th gen clutch in with MT90 and a steel clutchline. Bled the system and checked everything. Pedal has no resistance until the last inch before it hits the floor. Thinking its one of the cylinders or maybe both. Any ideas? cheapest place to get either of them?
Old Dec 18, 2005 | 11:13 PM
I30tMikeD's Avatar
If the hydrolic system was working before the clutch install I would guess you have not bled it correctly. Pretty small chance that it happen to go bad at the exact time a clutch job was done. It has taken me hours to completely bleed my clutch before
Old Dec 18, 2005 | 11:53 PM
Nismo's Avatar
does your slave cyl move while you press the clutch?
Old Dec 19, 2005 | 02:59 AM
kashman15's Avatar
im not sure. no one's around to help me but i'll look into it. what if it does move?
Old Dec 19, 2005 | 03:48 AM
nitromax's Avatar
what's your bleeding procedure, since you're doing it alone? and did you use brake fluid that had been opened b4? fluid absorbs moisture, over time it can be useless.
user 11122324
42
Jul 18, 2022 03:35 PM
t6378tp
Sep 29, 2018 04:27 PM
knight_yyz
Nov 1, 2015 01:34 PM
