View Poll Results: which do you think would be a better exaust performance design?
one 2.5" pipe for each header all the way back
50.00%
two 2.5" pipes merge into one 3" y pipe to 3" catback
0%
I don't know or was confused by lack of space in question
50.00%
Voters: 2. You may not vote on this poll
exaust 02 sensor question/ pipe poll
Old Dec 18, 2005 | 11:14 PM
PTownMax's Avatar
I still miss the max
first off my question is simple.
If you run a pipe from each header all the way back, use 2 cats, then your left with two pipes and one o2 sensor. Would this not cause a problem with your ecu trying to compensate for only sensing one pipe? Are there any maximas out there with true duals?
I thank you for any input you may give on the subject.
Old Dec 19, 2005 | 04:33 PM
PTownMax's Avatar
bump for response
Old Dec 19, 2005 | 04:59 PM
|Bijan|'s Avatar
UCF Lexus
have 1 o2 sensor in the y pipe for 1 side
have 1 o2 sensor in the b-bipe or cat for the other side
simple
Old Dec 19, 2005 | 05:39 PM
NmexMAX's Avatar
dot dot dot ...
Your engine doesn't give 2 flying a.ss ***** for the rear o2 sensor as long as it reads the required voltage osscilation. If you're so worried, get an o2 simulator...
Old Dec 20, 2005 | 01:45 PM
RA030726's Avatar
I'm nutty for Nissans
yea umm if you knew anything about true duals you would know about a cross over pipe ie X or H.
Old Dec 20, 2005 | 02:57 PM
PTownMax's Avatar
yes i'm aware of them but that was not my question.
Old Dec 20, 2005 | 05:12 PM
RA030726's Avatar
you obviously dont get the point.
hayne
Oct 5, 2015 11:53 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
