Definate Water pump leak?? (pics)
Old Dec 20, 2005 | 09:21 PM
DcMaN's Avatar
well it seems that it is the o ring seals on the water pump that went. im going to go buy one tommorow is the oem nissan the best one to get ? I checked all the hoses and they looked fine.
Old Dec 20, 2005 | 11:12 PM
I30tMikeD's Avatar
Not sure why your showing pics of the oil pan, unless your saying that is coolant going through the weep hole on to the oil pan....
Old Dec 21, 2005 | 04:35 AM
kc10fish's Avatar
sorry man but i would clean that area first then ck again and see if it come's back. also how do you know its coolant and not oil... there is one sure way but i digress....
Old Dec 21, 2005 | 04:40 AM
njmaxseltd's Avatar
I see a very dry bottom of an oil pan with a small amount of crud on one edge.
Old Dec 21, 2005 | 05:56 AM
alpicone's Avatar
Damn, I wish my oil pan was that dry!
Old Dec 21, 2005 | 07:01 AM
MDeezy's Avatar
@ oil pan pic (both of them).
Old Dec 21, 2005 | 08:43 AM
DcMaN's Avatar
that is all coolant around the edge of the oil pan. I cant find any other coolant besides that and it drips right down onto the floor from their.
Old Dec 21, 2005 | 09:31 AM
I30tMikeD's Avatar
That is probably a bad seal, leaking coolant thorugh the weep hole. Had the same issue last year. Pulled the pump and it was fine, just a bad seal. Replaced the pump anyhow. They are expensive from Nissan, paid around $200 IIRC. Later found that NAPA carries a water pump for our cars for about $100.
Old Dec 21, 2005 | 11:09 AM
matty's Avatar
There only $80-$90 from Nissan. Mine ran $80 from David B at Southpoint. New water pump and seals
-matt
Old Dec 21, 2005 | 11:13 AM
DcMaN's Avatar
i just went to nissan i paid 127 $ for the water pump w/ overnight delivery and and both o ring seals.
Old Dec 21, 2005 | 11:19 AM
matty's Avatar
Overnight delivery was probably $30
-matt
Old Dec 21, 2005 | 11:22 AM
DcMaN's Avatar
you have any tips for me when removing this water pump ? Im scared about when it says becareful while removing water pump, do not allow water pump to hit the timing chain that **** is scaring me : ( . How close is it to the timing chain. Isnt the water pump driven by it ?
Old Dec 21, 2005 | 11:46 AM
I30tMikeD's Avatar
-matt
Maybe my memory serves me wrong, but I could swear it was much more than that. But this has been almost 2yrs ago
Old Dec 21, 2005 | 11:56 AM
C MAX's Avatar
-matt
i got mine for 100 flat from nissan, that was my discount anyway.
Old Dec 21, 2005 | 12:25 PM
matty's Avatar
This is the write up I used...Its only tricky because the amount of space that there is.
http://forums.maxima.org/showthread.php?t=308680
Old Dec 21, 2005 | 12:34 PM
i30ds's Avatar
Armed and Dangerous
buddy of mine got his oem nissan water pump for his 96 from everythingnissan for around $80 shipped... local napa had it for a little over $100.
Old Dec 21, 2005 | 12:39 PM
dgeesaman's Avatar
Maintenance Monster
That definitely looks like coolant collected on that edge. As long as any coolant hoses in that area (if there are any, I don't recall) are dry at the joints, then definitely get a new water pump.
Dave
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
JoshG
51
Sep 21, 2015 10:41 PM
RWCreative
Sep 21, 2015 11:01 AM
Hdnseek
Sep 9, 2015 05:55 AM
