Weird Beepin
Old Dec 21, 2005 | 11:28 AM
tslrock514's Avatar
Weird Beepin
Well my car started beeping a couple days ago... it sounds like a wrist watch alarm going off. it only happens when my turn signals are on...wth is ia?!
Old Dec 21, 2005 | 11:30 AM
86maxima96's Avatar
I Broke OT
more details. is the key in the ignition? is the car running? lights on/off? door open?
Old Dec 22, 2005 | 11:01 PM
tslrock514's Avatar
yeah my car is on door closed and it is while im driving....but only when my turn signals are on......freaky!
Old Dec 22, 2005 | 11:16 PM
DR-Max's Avatar
Is your radio on while this was happening? Try turning the radio off and see if the noise is still there.
Old Dec 25, 2005 | 11:51 PM
tslrock514's Avatar
yes it is when it is on...what does that mean?
Old Dec 25, 2005 | 11:53 PM
DR-Max's Avatar
If your Max came equipped with Bose, it might be one of your bose amps getting ready to go out. That's usually a sign of a failing amp output channel. Mine started with a faint beep and started getting louder and louder.......but that was an aftermarket amp which I have had for many years. I ended up getting a new amp.
Old Dec 25, 2005 | 11:54 PM
tslrock514's Avatar
i took out the bose and put in a pioneer H.U.
Old Dec 26, 2005 | 12:05 AM
DR-Max's Avatar
If the sound is only present while your system is on, you have to try and track the problem somewhere in your audio system. If you are running an amp, try disconnecting each of the rca cables until you have identified the culprit. If you are running an external EQ or some electronic x-over, that could add complexity into trying to identify the problem. The more components you have, the bigger the chances are of introducing noise onto your sound system. If you are using cheap audio cables, that could also be the source of the problem. Ground-loop can also cause this, you should keep that ground cable as short as possible.
Old Dec 26, 2005 | 05:58 AM
njmaxseltd's Avatar
Replace the flasher relay.
AaronL
Nov 15, 2020 11:52 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
05RLS2
Sep 27, 2015 09:24 PM
yamehoo
Sep 24, 2015 10:21 AM
bennuss
Sep 11, 2015 05:55 AM
