Help Suspension Guys
Old Dec 28, 2005 | 02:57 PM
NCSU_MAX's Avatar
Maximoneypit
Well i installed my D2s about a month ago and am loving the handling. My question concerns the preload however. I feel that when i go over a bump in the road while accelerating sometimes the front wheels come off the ground enough for me to get a real floaty feeling in the steering wheel (and very little traction). Do I need to increase the preload on the fronts to help alleviate this problem? Thanks guys.
Old Dec 29, 2005 | 04:12 AM
NCSU_MAX's Avatar
Maximoneypit
bump.......
Old Dec 29, 2005 | 05:04 AM
njmaxseltd's Avatar
Do D2's have adjustable dampening??? If so increase it (firmer) to control the wheel better. What tire pressure are you running? To much and the wheel hits bumps hard causing it to rebound up and off the road for a second. Combine that with a heavy wheel and you need a firmer setting.
Old Dec 29, 2005 | 02:14 PM
NCSU_MAX's Avatar
Maximoneypit
yea the D2s do have dampening adjustability - mines set at 12 up front and 17 in the rear (out of 36). Right now ive got the stock 19.4 lb 5 spokes w/ about 35 psi up front and 38 in the rear. so the dampening and not the preload would fix this?
Old Dec 29, 2005 | 02:37 PM
MaximaSE96's Avatar
Maxima Owner
what height are u set at????
Old Dec 29, 2005 | 06:52 PM
NCSU_MAX's Avatar
Maximoneypit
bout a finger gap per wheel
Matt93SE
May 24, 2019 02:58 PM
Cotozic
Jun 28, 2017 08:01 PM
Chef N
Sep 22, 2015 11:20 PM
raffivegas
Aug 23, 2015 09:54 PM
maxipower
Aug 21, 2015 11:10 AM
