Bad Noise. . . Not too sure.
I'm experiencing a bad a loud noise. A "wob, wob" like noise that increases with speed.
I pretty much hear it winding up and getting louder and faster as my speed increases.
Clutch in while driving and I still hear the noise.
I hear the noise if I'm in gear and no throttle.
Noise is comming from the driver side
Wheel off, nothing is out of place: Guard behind rotor, is fine and out of way, not lines in the way, Axle seated properly (was replaced very recetnly).
I just had the car up on jack stands, and put it in gear and let it go while I listened for the noise. When the speed increases I feel/hear it, it sounds like the rotor is loose or some type of knocking (metal on metal) similar to that but the rotor is on tight.
I worry the sound could be the clutch maybe. .
but if so when I dis-engage, I shouldnt hear the noise anymore.
I'm scratching the noodle in search of a solution. At most I'm thinking wheel bearing. . . but that is more when turning and not a wob wob sound, you can hear and feel (thru the dead pedal).
Any input is greatly appreciated.
but if so when I dis-engage, I shouldnt hear the noise anymore.I'm scratching the noodle in search of a solution. At most I'm thinking wheel bearing. . . but that is more when turning and not a wob wob sound, you can hear and feel (thru the dead pedal).
Originally Posted by i30ds
Probably wheel bearing.
I didnt think a wheel bearing could be this loud. I'll get new ones pressed in.
thanks all.
220k+ A32
25
Oct 3, 2015 09:09 PM
RealityCheck
Oct 2, 2015 06:34 PM
