Engine Knock after manifold install
Old Dec 29, 2005 | 09:20 AM
SDot82's Avatar
Ok so here's the problem the engine is making a knocking sound after we installed the 00VI. I did not drop anything down into the cylinders and my friend said he didn't either, we were both very careful when the upper manifold was off. When we took everything back off we didn't see anything down in the cylinders at all but we did see some coolant. Any ideas?
Old Dec 29, 2005 | 09:39 AM
FrostMaxima's Avatar
Sounds like a Head Gasket to me, and did you have the heads off also or just the manifold?
Old Dec 29, 2005 | 09:46 AM
SDot82's Avatar
Just the manifold was off, but the coolant hose from the rear valve cover to the front valve cover was cracked. But do you think the coolant could be causing the knocking?
Old Dec 29, 2005 | 09:51 AM
risingmist's Avatar
i did the install also, and ig ot the same noise. everything seems to be working fine, except my aicv.
Old Dec 29, 2005 | 10:12 AM
Donald199's Avatar
How could it be the HG if all he did is the intake manifold.
Old Dec 29, 2005 | 11:17 AM
SDot82's Avatar
So your car didn't make the knocking sound before you did the manifold and after you did it thats when it appeared. Did the knocking go away after awhile or is it still there. I ask this because I can't remember if it made this sound from when I installed the 00VI on my car (about 1 year ago).
Old Dec 29, 2005 | 11:26 AM
s0ber's Avatar
Mine does it as well, you heard the video Sdot... is it like mine or worse or less severe? I am ignoring it.
s0ber's Avatar
When I put my ear to it, sounds like its coming from inside the manifold, right in the middle of both heads..
Old Dec 29, 2005 | 11:30 AM
s0ber's Avatar
What coolant hose from the RVC to the FVC are u talking about?
Old Dec 29, 2005 | 11:39 AM
SDot82's Avatar
I believe its a coolant line really didn't check, but its the one next to the timing chain cover and fuel rail.
Old Dec 29, 2005 | 11:42 AM
SDot82's Avatar
Yeah I heard your video it sound something similar to your but not exactly I'll try and get a clip of it. But maybe its something with the 95-96 models that are making it make this sound because his is a 1996 SE. Like the EGR?.
Old Dec 29, 2005 | 11:48 AM
matty's Avatar
Thats a Valve Cover Breather. No coolant runs through that line and there is, you have a huge problem..lol. I was doing the manifold gasket on my buddies car and that was ripped..I put some electrical tape on it. That shouldnt cause any problems if thats ripped a bit from being dryed out.
-matt
Old Dec 29, 2005 | 11:49 AM
s0ber's Avatar
thats a vacuum line or something, its not coolant.
mines cracked as well.
Old Dec 29, 2005 | 12:03 PM
SDot82's Avatar
oh, it was a late night
Old Dec 29, 2005 | 12:14 PM
SDot82's Avatar
What do you all think drain the oil and start it up again? Or just say F it and rev the hell out of the engine and blow it then drop a 3.5 in there (J/K). Serouisly what do you think?
Old Dec 29, 2005 | 12:38 PM
s0ber's Avatar
I think you should post a video :P lol
Old Dec 29, 2005 | 09:20 PM
SDot82's Avatar
Update: We took out the spark plugs and cranked the car (suggest buy a guy that owns a Performace Car Shop). After we plugged everything back up the car won't turn over. So we are going to try and get some new spark plugs tomorrow because the old ones looked really bad.
Old Dec 29, 2005 | 10:23 PM
s0ber's Avatar
wtf u mean it wont start back up?!?! O_O i dont think all 6 plugs could have died at the same time
Old Dec 29, 2005 | 11:20 PM
SDot82's Avatar
It won't start up now, it just cranks. I don't know WTF happened to his car it's like it's possessed. Also the back 3 plugs had oil on them (meaning oil was on the coil pack and spark plug).
Old Dec 30, 2005 | 06:45 AM
matty's Avatar
Check your upper manifold gasket. Make sure that its mated correctly to the lower manifold. You did replace that correct ?? Sounds to me like somthing happend during the install. Something from above. Something that you couldnt control
-matt
Old Dec 30, 2005 | 03:02 PM
SDot82's Avatar
Got her running again
Well we changed the spark plugs, replaced oil and doubled checked everything. Then he started the car up and............the engine was still knocking and it's a loud knock too. So lets just say he was not happy person, so me being the person I am said "Fock it lets take for a drive, its the least we can do since we got it running again." He said "Man, I don't know about that." So we back it out of the drive and start driving it and the knock speeds up with the cars acceleration. Things are not looking to good until I said turn around and as we turned around the knock stops for a second. Then the knock comes back for about couple more seconds and is gone again this time it does not not for about 30 seconds. This goes off and on for until the knocking stops completely. We were some very happy people when the knocking stopped. I will post a short video of his car running when putfile gets done with maintenance.
Old Dec 30, 2005 | 03:04 PM
s0ber's Avatar
what the ****? lol
Old Dec 30, 2005 | 03:06 PM
s0ber's Avatar
Your knocking sounds worse than mine, because if you can hear it in the car. omg.. you cant hear mine even in the engine bay, u have to stick ur ear on the manifold.
Old Dec 30, 2005 | 03:12 PM
SDot82's Avatar
Yeah, it was loud I wish I took a video of it before the knocking stopped but oh well.
Old Dec 30, 2005 | 03:22 PM
s0ber's Avatar
My knocking got quieter. shrug a few WOT runs did that.
Old Dec 30, 2005 | 05:30 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
did it sound like a metal on metal tap or like a small misfire like it wasnt running right
Old Dec 30, 2005 | 07:26 PM
SDot82's Avatar
It was a metal on metal tapping.
Old Dec 31, 2005 | 10:21 AM
SDot82's Avatar
Here is a video of the 00Vi both his car and mine. His is car is Black and mines is White. We still have some straighting up to do but that will come later one. http://media.putfile.com/CLIP003562
Old Dec 31, 2005 | 10:30 AM
s0ber's Avatar
was it ur car tapping or his?
Old Dec 31, 2005 | 10:45 AM
SDot82's Avatar
His car was making the knocking sound but went away. I just wanted to put my car in the video:attention , no real reason why mines is in the video. His car is working great now all his is waiting on is the rpm switch.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Matt93SE
May 24, 2019 02:58 PM
vingodine
45
May 21, 2016 12:46 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
