shes throwin me codes =(
7-1, 1-15. Multiple Cylinder Misfire and Fuel INJ Sys Right bank:lean. This just started this morning when i went to start my car, the check engine light started flashing about 10 seconds after i started driving, i was pretty sure that ment a misfire, so i turned the car off, turned it back on and i just had the steady check engine light. Last time i was driving my car it was fine, Its a 97 5 speed 160k on it, i was hoping bad gas maybe, and i was under 1/8 of a tank...who knows...any insight anyone?
thanks for the quick reply, I pulled the coils out, but i dont see to much sign of abuse in them, what exactly is the common sense method, or what methods can you use to determine if they are toasted?
A misfire from a spark would dump raw fuel into the exhaust causing a rich condition. A misfire from lack of fuel will cause a lean condition. I think you have a fuel related issue. Check your injectors.
Guys, one more question reguarding my max, I usually used plat oem plugs, never thought about them to much, at 140k(160k now) i threw in the coppers because i am broke. I know those dont last as long but after i put the coil packs back in i took it for a test drive and go no CEL but going up any sort of hill and diggin into the peddle a little i felt a noticable amount of sputtering, how long are the coppers good for? I love my max but its such a love hate relationship i've been waiting for a good reason to save some money for tillys 3.5 swap can always dream btw if this is any insight to the problem i currently have bad strut mounts, one bad wheel bearing, belt looks like its about to crack in half and bald tires lol, gota love the max i will not give up on her
Forge277
Jun 13, 2016 09:26 PM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
