Fog Light Install Questions
Old Dec 31, 2005 | 09:03 AM
djdirtyrice's Avatar
I heard that u can install fog lights on my 96 gle even though it dosent come with them all u have to do is cut holes and there should already be wiring ready to just plug right in? is this true because i dont wanna cut holes or take my bumpercover off without being sure about this.
Old Dec 31, 2005 | 09:12 AM
|Bijan|'s Avatar
UCF Lexus
SOME are like that, not all....
If not, you can buy a kit from courtesynissan or pinnaclenissan.com
Old Dec 31, 2005 | 09:24 AM
thanks for the quick reply, how hard is the kit to install?
Old Dec 31, 2005 | 01:57 PM
95GLEMAXX's Avatar
my95 GLE had the wiring, so i dont see y not ...i would think that maybe the GXE doesnt have it bc its the bare bones maxima, but GLE's should......
to be sure, look under ure bumper where the fog lights would be and you should see a light bulb harness tied to something by liek duct tape
Old Dec 31, 2005 | 01:58 PM
95GLEMAXX's Avatar
the kit is easy to install btw....the hardest part is making the holes
u just need to headlight switch w / a fog switch from a 95 and the relay
Old Dec 31, 2005 | 09:14 PM
descent's Avatar
whats the difference between the 97-99 fogs and the 95-96 fogs? I found these on ebay and i am thinking of buying them. i have the GLE so i assume i have the wiring and all, the holes just arent drilled.
http://cgi.ebay.com/ebaymotors/97-99...spagenameZWDVW
Old Dec 31, 2005 | 09:44 PM
rteenie22's Avatar
95-6 and 97-9 had different bumper designs. the fogs on the 97-9 look much more aggressive than their older counterparts. im sure they are mechanically the same jus aesthetically different
Old Jan 1, 2006 | 03:50 PM
96blackmaxSE's Avatar
boost me.....
97-99 fogs and 95-96 fogs are NOT interchangeable....
all you need is...
1. a switch for the fogs/or a new headlight stalk with fogs on it
2. the brackets for the fogs.
3. the bolts for the fogs
4.the fog housings
5.bulbs
that is all
all 4th gens have the harnesses from the factory... GXE and GLE
Old Jan 1, 2006 | 03:52 PM
boost me.....
wait....you also have to have a relay if you use a factory stalk to control them....
OR
if you rig up your your own pos. and ground wires and a generic switch to control them you dont need a relay
(someone correct me if Im wrong)
Old Jan 1, 2006 | 05:24 PM
so on my gle when i turn the lights on the fogs will automatically come on unless i put some switch or sumthin?
Old Jan 1, 2006 | 09:48 PM
pavelsmax's Avatar
i have a 95 gxe and mine came pre-wired. i would recomend getting the bumper cut by a proffesional as mine came out kinda crappy.
Old Jan 1, 2006 | 09:51 PM
boost me.....
if you use the factory switch from an SE with the fog switch on it you have to have a relay to turn them on at all...
if you run a positve and ground wire yourself(not using factory wires) you can hook up an on/off switch and turn them one without using a relay
Old Jan 1, 2006 | 10:02 PM
95GLEMAXX's Avatar
its much easier to just get a relay tho...ooo so gxes do come pre wired...my bad..but also i had to learn this the hard way... i got a headlight switch for my 95 from a 96 and it didnt fit, bc the harnesses were different...so just to be safe, make sure u get a switch from ure exact year, which would be 96
Old Jan 1, 2006 | 10:26 PM
DR-Max's Avatar
You might have the wiring but you will have to install your own switch inside the car as the switch that is built into the signal stalk, for foglight equipped maximas, will not be there. Just pull one of the plastic shields down there and see for yourself.
Old Jan 2, 2006 | 02:19 AM
Jepht20's Avatar
Custom User Title...
INCORRECT
my 95 gxe did not come with the wiring harnesses. it had some wiring that stopped at a random harness near the battery, but no actual harnesses to plug into the fogs so i had to custom do it. (i got the harnesses from a junkyard and created the rest of the wiring myself.
Old Jan 2, 2006 | 12:57 PM
UncleMax98's Avatar
I heard that GXE with the Security & Convenience package is prewired for fog.
vingodine
45
May 21, 2016 12:46 PM
EuroDriver
Sep 14, 2015 06:08 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
98nismomax
Aug 13, 2015 12:44 PM
