Belt tensioner to replace alternator
Old Dec 31, 2005 | 11:47 AM
TightBlack97's Avatar
Alright i am changing my alternator out for a new one. I am at the stage where you are supposed to loosen the belt tensioner to get the drive belt off. I know that you are supposed to turn it like a million of times.
But what way am i supposed to turn it left or right to loosen it? Because Bags(screenname) on here said that im supposed to turn it opposite to screw it loose. I guess I will just keep on turning it until I feel that the drive belt is loose enough.
Any help or ideas are great!!!!!!!!!!??????????
Old Dec 31, 2005 | 11:59 AM
CreativeDesignz's Avatar
yea its a reverse threaded bolt. u must first loosen the tensioner pulley bolt. its 14mm. dont take it off just loosen. and then for the bolt on the top that tensions the bolt, spray it with some wd-40 mine froze on there and i turned it too hard and snapped the little shaft it goes on. its a 25 dollar part and u can only get it from nissan.
vortechpower's Avatar
You must first loosen the nut on the tensioner pulley before turning the adjuster to the left. The nut on the tensioner pulley is a 14mm located in the middle of the pulley. You will need a wrench to do this and maybe some type of breaker to get it loose. You can see this pulley from above ( its the only 1 with no ribs) but will have to loosen from below.
Old Dec 31, 2005 | 12:01 PM
Come help me mang!!!!
Old Dec 31, 2005 | 12:09 PM
Im at work right now. Its not hard just alittle time. Got to go out to dinner with the wife after work... I can answer some Q's until 4:30 though
Old Dec 31, 2005 | 12:12 PM
Your going to need to remove the bolts holding the a/c compressor on. I think its 4 long bolts (14mm)
Old Dec 31, 2005 | 12:15 PM
Need to take the fan (s) out. The plastic under the front of the car.
Old Dec 31, 2005 | 12:24 PM
Yeah I know all that thanks!!!!
Old Dec 31, 2005 | 12:26 PM
Screwed that one up!!!! Tried to adjust the tensioner first now I got it back to normal.
Old Dec 31, 2005 | 12:54 PM
Def loosen the bolt on the pulley before turning the adjuster. Once you get in there and see how it works you will better understand the thing. You better hurry, not too much day light or heat left...
Old Dec 31, 2005 | 01:08 PM
Nah I quit doing it for now but I got it figured out. Thanks a lot for the help!! Ill buy you a 12 pack of something. I got to go to work in about 45 minutes.
Later
Happy New Year!!!!
Old Dec 31, 2005 | 01:22 PM
vortech u do not need to loosen the nut from underneath. you dont need a breaker and you dont need to loosen any of the a/c compressor bolts. take off the rad brackets, lower rad hose, push the rad up,pull the alt out. i changed my alt about 8 times. due to getting crappy high output ones. screw can-am im waiting for my ohio gen to come. but yeah alot of the things u posted do not need to be done. next time just edit one post instead of making 5 new posts. also you dont need to take the fans out. just push them up...
Old Dec 31, 2005 | 01:28 PM
MaximaSE96's Avatar
Maxima Owner
i never did anything with the fans or radiator hoses...take the a/c compressor bolts off to move it out of the way and u can slide teh ALT right out....
Old Dec 31, 2005 | 02:57 PM
nismology's Avatar
It's reverse threaded but you still go counter-clockwise to loosen it.
Old Dec 31, 2005 | 02:58 PM
nismology's Avatar
To the original poster, don't loosen the pulley nut too much though. Just enough so you can turn it by hand slightly.
Old Dec 31, 2005 | 03:38 PM
you took everything that i posted and said it in a different way...
Old Dec 31, 2005 | 03:59 PM
nismology's Avatar
Not really, because it's possible to not remove it all the way and still loosen it too much. It should be almost finger tight.
Old Dec 31, 2005 | 04:11 PM
everything i posted was basically reposted by u in different words. not to mention 1/2 of the steps u added were pointless and take way too much time. alternator swap shouldnt take ne more than 45 minutes in and out and new one back in.
Old Dec 31, 2005 | 04:27 PM
nismology's Avatar
WTF are you talking about?? I never posted any steps to alternator removal. Are you drunk?
Old Jan 1, 2006 | 08:37 AM
totally was drunk lol. wow i have no idea what that was about. Happy New Year, haha. sorry dude lol. hang overs suck =/
Old Jan 1, 2006 | 08:57 AM
Post ******!!!!!!!!!
tsi6001
Oct 3, 2022 10:23 PM
mvm062
Nov 30, 2020 09:00 AM
PH98I30
19
Jun 13, 2016 02:38 PM
kenc15
Sep 25, 2015 06:38 AM
JMag90
Aug 25, 2015 09:17 AM
