grinding sound after starting in the cold
Old Jan 1, 2006 | 03:33 PM
kosmo886's Avatar
Hey
I live in MA and when i start my car when it is cold out i hear a grinding noise for about 1-2 seconds. I turn the key, the starter turns, the engine starts then i hear imdeiatley the grinding like noise for 1-2 seconds. this occurs most frequently in the morning after the car has been sitting out all night, or even after work when the car has been sitting in the cold for 8 hours. It does not happen if you drive for a little while, warming the car up, then go into a store for example. Does anyone know what this might be and if it is something i should be worried about.
Thanks!
Old Jan 1, 2006 | 03:49 PM
blkmaxx97's Avatar
Sounds like the starter is hanging maybe.
Old Jan 1, 2006 | 04:06 PM
whitemax21's Avatar
Sound like your starter is going out. Cheapest place to buy one will be from advance auto parts or autozone plus, you get a lifetime warranty. I bought one from advance 2 years ago. I had same problem. I think, someone else correct me if I am wrong, the gear that engages to spin the flywheel doesn't retract fast enough and the sound you hear is the gear grinding on the teeth of the flywheel. I have had no problems since. Also, you are probably familiar with the mentioned parts places, but they will match each others price.
Old Jan 1, 2006 | 04:37 PM
kosmo886's Avatar
just to add something...i had this same problem last winter and i just kind of ignored it. I had no additional problems until reccently when it started getting cold again. I would have thought if my starter was going that i may have had some problems in the warmer months between say march and november. Im certainly no expert however...just throwing this out there.
Old Jan 1, 2006 | 05:20 PM
JonnyCum Lately's Avatar
Its definitely your starter. I had the same problem a few weeks ago when the weather was cold. I ended up replacing the starter because it was working on an intermittent basis.
Old Jan 1, 2006 | 05:22 PM
Chucks98's Avatar
You may want to try this before buying a new one
http://www.motorvate.ca/mvp.php/516
Old Jan 2, 2006 | 12:52 PM
UncleMax98's Avatar
I had the exact problem a few years ago. Took the starter apart and regreased it per the motorvate web site instruction. If you have time, I would recommend to regrease the starter vs. getting un unknown rebuilt.
Old Jan 2, 2006 | 03:55 PM
96ItaliaSE's Avatar
il massimi bassi
Your in massachusetts? I can show you how to regrease your factory starter, Its not to bad my 1996 did the same thing and the 1995 I just sold did it also. Those starters are great they just get dry and start to creak. You can get a new starter....but id much rather PB PLAST and MOBIL Grease for $6.50 in parts.
Old Jan 2, 2006 | 04:00 PM
PFCGlass's Avatar
I had that same exact problem a year ago, but it turned out to be my battery. My car still hangs -sometimes- during the really cold mornings in winter, but most of it was nothing my new battery couldn't solve. My starter will probably be the next thing I fix.
Old Jan 3, 2006 | 05:56 AM
kosmo886's Avatar
Thanks for all the advice...im gonna check it out and see if regreasing the starter is something that i can handle. One other quick thing though, reccently it is taking longer for the car to start then it used to...the starter has to turn more then before. i know this happens in the winter when its cold and i know many cars that take much longer then mine, but it was just something different then what was happening before. Do you think this is a problem? Maybe linked to a bad starter? or do you think regreasing would improve this as well?
Old Jan 3, 2006 | 06:07 AM
Chucks98's Avatar
Not to high-jack that thread or nothing......but after reading this thread, I went out to the car yesterday morning and had my S/O start it while I was under the hood. What I thought to be a starting noise generated from a loose belt.....actually turned out to be a starter noise.. Needless to say..Mine is coming out also
Old Jan 3, 2006 | 10:46 AM
MaxKlinger's Avatar
Same thing happened to me two years ago, the same grinding noise after a start. The spur gear that engages the starter to the flywheel was not disengaging correctly and the engine was driving the motor. I drove around like that for a while and then finally had it replaced.
Old Jan 10, 2006 | 12:55 PM
kosmo886's Avatar
thanks for all the help...i ended up going with a new starter because the other day my car decided to not start haha. o well, i got it towed for free with AAA and got the starter so im happy
markevans999
Sep 10, 2015 04:29 PM
jfl330
Sep 4, 2015 01:44 PM
TheMafia
Sep 4, 2015 08:26 AM
trungg86
Sep 4, 2015 04:58 AM
sdotcarter
Sep 2, 2015 09:53 PM
