VQ is in bad shape
Old Jan 1, 2006 | 03:42 PM
97Se5spd's Avatar
VQ is in bad shape
My car has really been acting up latley, when its above 2k rpm, its great but below that, it bucks and when i come to stop it almost dies and vibrates badly. Also there is a heavy hesitation when i step on the gas even in the lightest way. I run the car on 93 octane and jus changed the plugs. I have no idea what this could be. Maybe its tranny? Its an auto with on 58k on it!
Old Jan 1, 2006 | 03:45 PM
LA02MAX's Avatar
motor mounts....same EXACT thing happened to my mom's 2k max at around 195k (yes, it now has 209k on it ) and three of the motor mounts needed to be replaced...
Old Jan 1, 2006 | 04:02 PM
MaximaSE96's Avatar
Maxima Owner
any codes....sound like the issue i had with my 96...ended up begin 2 coilpacks
Old Jan 1, 2006 | 04:51 PM
97Se5spd's Avatar
i think im gonna take it to the dealer and have her plugged in. and im gonna have my mechanic check out the motor mounts also. Thanks
Old Jan 1, 2006 | 07:21 PM
konak85's Avatar
at a stop, in drive, are the rpms around 500
Old Jan 1, 2006 | 07:28 PM
97Se5spd's Avatar
yes they are and I think its to low of an idle for the car, but my friend has a 97 5spd with 137k and it idles at 500 and is fine so I dont know whats wrong.
Old Jan 1, 2006 | 11:41 PM
Garrick's Avatar
I have the same problem. Sometimes it bucks, sometimes it doesn't. I have the Knock Sensor and Thermostat code. I'm thinking coilpacks.
Old Jan 2, 2006 | 12:45 AM
Luigi38's Avatar
you might wanna change what you know it's wrong, b4 changing unecessary parts
Old Jan 2, 2006 | 12:56 PM
Garrick's Avatar
Touche'
Old Jan 2, 2006 | 01:57 PM
DR-Max's Avatar
Look up the how-to for pulling codes from the ECU. This is very easy instead of paying the stealership $75. Once you get the fault codes, look it up (its in the faq). Then hopefully you'll find out what is wrong with your car.
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
Marc2theMax
Sep 28, 2015 08:13 AM
