Oil Leak How Serious?
Old Jan 2, 2006 | 05:28 AM
speed racer's Avatar
Last week when I was installing my y-pipe I noticed a leak coming from where the transmission attaches to the engine. I looked in the FSM and I believe its the Rear Cover from the Oil Pan. I have an auto transmission with 130,500 miles on it. Currently the oil is not dripping on the ground, but I want to know if I should monitor it, take it to a professional, or change it right away. Also, if anyone has done something like this.
Old Jan 2, 2006 | 05:58 AM
njmaxseltd's Avatar
Clean the area and keep your eye on it for a while. Watch how much actually comes out over time. The decide if you want to rip things apart to fix it.
Old Jan 2, 2006 | 10:52 AM
Tim96I30t's Avatar
I would get it fixed ASAP looks pretty bad, might only leak when driving
Old Jan 2, 2006 | 11:46 AM
L0R1DA's Avatar
If you're running full-synthetic, that leak will keep going like a hemophiliac. Just run some 10w30 conventional petroleum oil and monitor it until you get it fixed (by replacing a gasket or oilpan).
Old Jan 2, 2006 | 03:16 PM
thanks for the replies. I'm going to take the advise that NJmax had sugested. I been running Amsoil 5w-30 for the last 10,000 miles and I don't think the oil being synthetic would cause the problem to get worst. I still need to check the oil level and whip down the part.
Old Jan 2, 2006 | 03:49 PM
L0R1DA's Avatar
Synthetic oil (esp. 5w30) is much thinner than conventional oil at cold temperatures. I have heard of incidents where oil leaks become worse or apparent for the first time when synthetic is introduced into a system that ran on conventional oil previously. However I dont know if this is your situation, so good luck with your ride.
Old Jan 2, 2006 | 05:13 PM
Thanks for the info. Yea, I've done my fair share of research and that is why I didn't want to go with the Mobil 1 fully synthetic since the symptons you mentioned would appear more severe. This is the first Winter with the Max. I'll keep the org. posted on what happens. I need to look further up in the engine. Right now I'm thinking the repair would be removing the upper oil pan, but I'm looking at the FSM and can't tell if that black rear cover has any sealent behind it.
Old Jan 2, 2006 | 09:39 PM
DcMaN's Avatar
what is that thats leaking anyway i have the same leak but no where near as bad its very slight it doesnte ven hit the floor. IS it the definate rear cover freom the oil pan ?
Old Jan 3, 2006 | 10:16 AM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
I have the same leak on my car. I check fluid levels and they seems to be ok.
Old Jan 3, 2006 | 01:22 PM
i30ds's Avatar
Armed and Dangerous
That leak is from the rear main oil seal (goes over the end crankshaft) in order to replace it you must remove the transmission and then the clutch or torque converter. I replaced mine when I was in there installing the 5th gen clutch and it is a REAL b!tch.
Old Jan 3, 2006 | 01:45 PM
I thought only Manual Transmissions have that rear main seal not automatics.
By the way the Oil level is pretty stable. I can live with this for a while, but i'm sure it will get worst.
Old Jan 3, 2006 | 07:25 PM
i30ds's Avatar
Armed and Dangerous
No, autos have it too... my car used to be an auto... there is no difference between the engines of MT and AT.
Old Jan 5, 2006 | 04:55 AM
After reading about the RMS I have some questions of how it doesn't affect autos as much as manual transmissions.
First off wouldn't the Drive Plate behind the RMS be affected the same way as the FLY Wheel for Manuals? I would think that it would cause gear slippage as well.
And second does anyone know the name of the tool to put back the OIL Seal Retainer and lower gasket (Half Moon SHape)?
litch
123
Jan 4, 2024 07:01 PM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
