Replacing strut mounts
Old Jan 3, 2006 | 09:00 AM
baltimax's Avatar
I recently found that my passenger side strut mount is loose. How can I fix this? Should I take it to a shop or do it myself?? Please give any advice or experience and/or directions if you've done this yourself.
Old Jan 3, 2006 | 09:08 AM
MaximaSE96's Avatar
Maxima Owner
do it urself....get a sprig compressor from a aprts store (rent it) take ur spring/strut assemblt off the car...compress the spring...unbolt the mount replace mount torque to spec...take of spring compressors install assembly on car
http://web.archive.org/web/200108060...x/springs.html
thatsf ro complete spring/strut replacement but u have to almost the same work to an xtent
Old Jan 3, 2006 | 10:30 AM
Fr33way™'s Avatar
Wild for Width
If you have the time (say 2hrs most) you should do it.
I don't know if any write-ups list this but when you are removing the bolts for the strut that attatch it to the knuckle/rotor assembly put a small jack (I used a spare Honda/Acura OEM jack with the cup style) under the assembly so that it is just touching (not pressing up) on it. This will make getting the bottom bolts slide out very easily. The top ones are cake.
Credit:MDeezy
Matt93SE
May 24, 2019 02:58 PM
95Maxi
35
Sep 2, 2015 10:37 AM
FanaticMadMax
Aug 10, 2015 08:55 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
laparka66
Aug 6, 2015 09:36 AM
