Motor Mount Help
Motor Mount Help
So I decided to check my motor mounts out tonight, big mistake i wish i hadn't seen how horrible they are. my rear motor mount is completely shot and the front is close. I was checkin everythin out on here and polyurethane seems to be the way to go but $85.00 a peice?? Nothin in forsale on here nor ebay any recommendations? is polyurethane really worth the extra 30 bucks? Thanks
http://www.suspension.com/nissancars.htm
$80 for the set. It will be a bit more solid then stock, but youll eliminate most of your wheel hop and these are "slide" in. You dont need to buy an entire new mount
-matt
-matt
I just hopped on google, found a couple different places but didn't find that one matty shows. Do you know if those ones are polyurethane or not I couldn't tell on the site. Thanks for the site tho def. made my night better
Rear Motor Mount
Hello:
I saw you were in the market for a poly mount for the rear. I listed an OEM rear mount in the for sale section that is in great shape in case you want to install it while you continue to search for some urethane/poly mouonts for a decent price. Look for the the thread "1998 SE Rear Motor Mount" and see if you could use it. Make me a reasonable offer and hopefully we can make a deal -- I have no use for it.
Thanks,
Ted, Chicago
PM me or send a msg to my email tfvesquire@aol.com
Thanks,
Ted, Chicago
in my 98 I got the Energy Suspension mounts from Cattman. They were under 100 for the inserts, then you will just need to take them somewhere and have them pressed in. In my 95, I filled my stock mounts with urethane, this also seems to be holding up well so far, but the mounts have only been back on the car for about 1k. This cost about 25 bucks from urethane from McMaster Carr. The down side to this, is that you should let the urethane set up for a few days (I let mine set up for a week because I had the motor out of the car). Goodluck.
Has anyone tried the ones that matty showed us? Or does anyone know if they are good??? cardana you said they have to be pressed in? i thought they just slid in, guess i was wrong...who would press them in for me? do I have to find a machine shop or could like midas do it.
If you can get the old ones out I saw someone post up about using their car to press the polys in. Just set the mount with the bushing under a tire and slowly lower the car on top of it. I havent tried it myself, but it is supposed to work.
haha thats awesome, how would you get the old one out if it takes the weight of the car to put it in lol
Ya I'm pullin my mounts off in about 10 mins just thought i'd check up see what the new feedback is. I don't really have to worry about the center part where the bolt goes through...thats already detatched along with most of the rubber lol! sounds like i'll be bustin out my hammer on this one eh? Thanks guys
Here is an easier way to remove the "ring" from the old bushing
Remove the rubber.
Take apart a hack saw.
Insert the blade through the motor mount.
Assemble the hack saw.
Cut a small 1/4" section of the "ring" out. Be careful not to saw into the mount itself.
Remove the 1/4" section. You may need to use a screw driver and a hammer.
Once that part is out all of the tension will be off the ring and its much easier to remove.
Again BE CAREFUL not to saw into the mount.
Remove the rubber.
Remove the rubber.
Remove the rubber.
Dubbya-completely brilliant! haha I wouyld so do that except I just found a place taht will press mine in and out for about 10 bucks so ya not worth my effort. Nice idea tho. so what do you all think about those mounts matty gave us? i need to order some mounts asap so i need some quick input. thanks guys
-matt
Oh sweet, now set meaning all 3? this almost sounds too good to be true
They come in sets of 2 and you can get em from Energy directly, or from Cattman or Sport Compact Only. Its just slight variations in the price and shipping times.
Well its been decided then, suspension.com is the winner, i'll give them a call in the morning and go from there, thanks everyone you've just saved me alot of time and a LOT of money, i was about to spend like 85 a peice
Ok so the ES kit contains 2 poly inserts? If I'm not mistaken, our engine uses 4 mounts: left/right/front/back. So basically you'd need to get 2 kits to replace the oem rubber inserts in each mounts, yes? I mean, might as well replace them all while you are doing the work. How about the transmission mount, I don't see anything from ES. What did you guys do with your torn-up tranny mount?
Originally Posted by matty
Where is the "ring" that needs to be cut out ??
-matt
-matt
Whered you get those from ???
-matt
-matt
cardana- I'm just going to get new ones from ES I don't trust myself filling those huge holes...if thats what you meant by filling them. I was going to pull my other mounts off (left/right) but can't figure out how the heck i'm supossed to get the bolts off the motor there's no room and they are on there good, i dowsed them with PB so we'll see later but any suggestions? Would you mind giving us that link to your thread, should make everyones life easier. How hard was it to fill your mounts and what is flexane???
Sorry for all the newbie questions I just want to do this right. Thanks
Flexane is made by Devcon in 80 and 94 Shore hardness. I used 94 its the stiffest. Its a 2 part epoxy type urethane. I just put tape over one side and filled the other, pretty simple, almost Jime proof.
Here is a couple of links on the subject.
http://www.geocities.com/ae82power/umounts.html
http://importnut.net/motormount.htm
^^thats it.
Air tools makes taking the motor mounts out much easier. When you do this make sure the ENGINE IS SUPPORTED. You have to drop the cross member. To get the front one out it has a bolt thru it with a nut on the other side...put a box end on the nut and hit it with some air on the gun. For the rear one take the driver side wheel off. Then take the splash guard off, the one that covers the tranny in the wheel well (not the fender liner). After you do that you will have a clear shot at the rear motor mount. You will need a bunch of extensions, and if you have 1/2" stuff I would recomend that (I broke a 3/8ths extension when I was doing this). For the rear one the nut is welded on the other side so there is not a need for another wrench. Make sure you are on the bolt good and then hit it with air. Once you have them loose most likley the bolts will not come right out because the weight of the engine is on them, so whe I did was put my floor jack where the engine and tranny meet with a 2x4 between the jack and metal. Then play with the jack until you release the tension binding the bolts. After you have done this you can drop the cross member, but I recomend leaving the jack in that same spot since the engine is no only being held in by the two side mounts. Have fun putting everything back together once you are done...its lots of fun
Im pretty sure you can just drop the cross member with out supporting the engine per Tilley. You can get to the rear motor mount from under the car pretty easy too. I watched my mechanic do this on my car. Basically just unbolted the mounts from the engine then dropped the cross member. Put on new mounts and replaced the cross member. When he was putting the cross member back up he did need to use a jack to align everything.
