Question for those with auto trans cooler.
To install it, you have to remove the plastic covers from the underside of the car. One I got back on without a problem, the other refuses to seat right and I think the hoses for the cooler are now in the way.
Did anyone else have this problem? Is there a way to route the hoses out of the way? Should I cut the cover to accomodate the hoses or what?
Jim
Jim
Jim
Jim
A pic link:
http://www.greghome.com/images/Maxim...oseRouting.jpg
Originally posted by Eric L.
You need to route the tubes as close to the center crossmember as possible. I did that and had no problems with clearing the plastic cover on the bottom. Just hold it in place with zip ties.
I just installed my B&M cooler last Saturday. I routed the hoses close to the centre crossmember as well. There is like a 1/2 inch gap and I ran both hoses in there, side by side. I then reattached the plastic covers back on and had no clearance problems. I followed Greg's photo instructions to a Tee except for the part where you lean back the radiator. Couldn't do that with the SC tube in the way.
'98 Maxima SE auto
V2 Stillen Supercharger
Stillen Body Kit
Courtesy FSTB
Koni Sports
Eibach Pro Kit
Obx Brushed Aluminum Pedals
B&M Supercooler
'98 Maxima SE auto
Stillen Body Kit
Courtesy FSTB
Koni Sports
Eibach Pro Kit
B&M Supercooler
...Did anyone else have this problem? Is there a way to route the hoses out of the way? Should I cut the cover to accomodate the hoses or what?
Jim
Jim
Yes, I had 2' of heater 3/4" hose and it was barely enough. I would recommend everyone get 3', if you are going to use it at all. It prolly isn't necessary, but makes the install look a lot cleaner.
Originally posted by bill99gxe
I hadn't noticed until now, but that explains why Greg used that extra 3/4" of hose as "cushion" when tying the tranny lines to the crossmember........now it makes sense....
'98 Maxima SE auto
Stillen Body Kit
Courtesy FSTB
Koni Sports
Eibach Pro Kit
B&M Supercooler
'98 Maxima SE auto
Stillen Body Kit
Courtesy FSTB
Koni Sports
Eibach Pro Kit
B&M Supercooler
Hi,
Which way did you face the B&M cooler lines? Any suggestions appreciated...thanks.
'96SE
Originally posted by magic_max
Hi,
'96SE
Hi,
'96SE
pears
Sep 18, 2015 05:25 AM
