Ypipe causing clutch to slip?
Old Jan 7, 2006 | 08:53 AM
kismias7's Avatar
I just had a warpspeed ypipe installed on my 96 maxima. As soon as I try to test out the added horsepower my clutch slips and my rpms redline as my car barely accelerates. Could this be caused by the ypipe? ECU? or just a shot clutch? IF it is the clutch could you please recommend a clutch for street driving as I dont race at the track or have turbo.
Old Jan 7, 2006 | 08:55 AM
RastaManMax's Avatar
Probably best to just replace it with an OEM clutch.
Old Jan 7, 2006 | 08:57 AM
tavarish's Avatar
fwd gone rwd cr00
check the fluid in the reservoir, you could have a leak in the line.
Old Jan 7, 2006 | 09:20 AM
MaximaSE96's Avatar
Maxima Owner
true true....how many miles on your max....itas might just be time for a new clutch...all depends on the previous owner if there was one and how they drove....
Old Jan 7, 2006 | 10:14 AM
nismology's Avatar
The amount of clutch fluid doesn't dictate how well a clutch grabs, at all.
Old Jan 7, 2006 | 10:24 AM
|Bijan|'s Avatar
UCF Lexus
Whoever the hell said that...
And NO...no mods besides an ENORMOUS amount of power (more than clutch rating) will make it slip
Clutch's slip because no grip = worn down = time for new one
Old Jan 7, 2006 | 11:27 AM
vortechpower's Avatar
Maybe you have an exhaust leak!! This can simulate a slipping clutch
Old Jan 7, 2006 | 11:35 AM
Nealoc187's Avatar
SLOW
Your clutch is probably worn out pretty badly, just not quite badly enough that with the stock amount of torque it would slip while in gear, but the added 15tq or so from the ypipe just pushed it over the edge. Which means that you need a new clutch.
BigLou93SE's Avatar
Originally Posted by Mxrider52
Ypipe wouldnt cause your clutch to slip. Your clutch could be shot. If it is the clutch go with a 5 gen clutch.
Check codes to see if you maybe have a bad knock sensor
Why would a bad knock sensor cause his clutch to slip?
Old Jan 7, 2006 | 11:37 AM
|Bijan|'s Avatar
UCF Lexus
Some of these jacka$$es need to be shot
Old Jan 7, 2006 | 12:05 PM
Nealoc187's Avatar
SLOW
lol I hope he was joking - because you know how everyone says "bad KS" for everything, maybe that was his little joke... I hope...
Old Jan 7, 2006 | 12:28 PM
Mxrider52's Avatar
I support for what?
Hell just go tell everyone they got a bad KS and they will replace it and say wow what a difference that really fixed it lol
Old Jan 7, 2006 | 12:47 PM
BigLou93SE's Avatar
What? I don't think the above post was a joke...
Old Jan 7, 2006 | 12:59 PM
|Bijan|'s Avatar
UCF Lexus
Jesus.....
Old Jan 7, 2006 | 01:27 PM
MorpheusZero's Avatar
AFAIK it doesn't really add any peak torque (or not very much), just makes the curve far more favorable in the nether regions of the rev range. If he's not making any more peak torque then it won't make a difference. I think his more enthusiastic "testing" right foot nudged it over the edge.
Old Jan 7, 2006 | 01:32 PM
Nealoc187's Avatar
SLOW
Ypipe adds about 15ft-lb of peak torque, and throughout the powerband.
Old Jan 7, 2006 | 02:15 PM
...4 ftlbs?
Makes me want one badly though.
Old Jan 7, 2006 | 02:40 PM
Mxrider52's Avatar
I support for what?
at 6000 rpms it making 27 ft lbs
Old Jan 7, 2006 | 04:22 PM
nismology's Avatar
So? The point is not enough peak torque is added to be the difference-maker.
Old Jan 7, 2006 | 04:54 PM
user 11122324
42
Jul 18, 2022 03:35 PM
TKHanson
Nov 24, 2018 01:39 AM
mpbclutch33
Dec 26, 2015 11:11 AM
leatherneck
Sep 30, 2015 09:16 PM
