How do I know if my oil is circulating or not?
Old Jan 7, 2006 | 01:17 PM
Tyrexx's Avatar
My oil light is on and the car doesn't start, I'd like to know the oil is doing it's job. I can't think of a way to tell so i'm hoping one of you does
FYI I may have blown/overspun my oil pump
Old Jan 7, 2006 | 01:26 PM
Nealoc187's Avatar
SLOW
Oil light on means low oil pressure. Your motor might be toasted if the oil light is on in conjunction with the car not starting but we need more info. Does it turn over when you try to start it? Is the motor siezed such that it won't even turn over? Any strange noises when you try to start it, or the last time it ran? What were you doing when the problem occurred?
Old Jan 7, 2006 | 02:32 PM
njmaxseltd's Avatar
Engine has to be running for the light to turn off.
Now the real problem is why isn't your car starting.
Old Jan 7, 2006 | 03:51 PM
Tyrexx's Avatar
http://forums.maxima.org/showthread.php?t=448295
I missed a gear, The motor ran and started fine (perfect), I drove about 3 miles or so and it killed when I put in the clutch and hasn't started since. The engine turns over easily, It's definatly not siezed at all (yet anyway)
I have another cam sensor to try but I obviously want the oil to be circulating when the engines running and before messing with anythng I was wondering if there way to tell if the oil is circulating or not.
I'm hoping I popped some seal near the oil pump
Old Jan 7, 2006 | 03:55 PM
marco polo's Avatar
PLEASE HELP,for some reason I can start a thread can some start one for me PLEASE. My problem is: Just the other I put gas in and my car did not start, it make alot of clicking noises in the starter when i turned the key,eventually 5 minutes later it started. I was 350 miles away from home. The next morning again starter clicks but doesn't start. A few minutes later it starts. Decided to leave in the garage and borrow my dads truck. I figured the starter was going out,still original one my maxima is a 97 auto with 198,000. Well, I got a new starter and replaced it I didn't notice any loose wires or something out of the ordinary. When I tried to start it I got the same noises click,click, really fast. I checked the battery and I got 12.56volts. What gives? Any suggestions. Thanks great forum
Old Jan 7, 2006 | 04:07 PM
Tyrexx's Avatar
Make sure everythings connected tightly and that all the connections are clean, then if that doesn't work try using a different battery.
Old Jan 7, 2006 | 05:04 PM
marco polo's Avatar
I checked the connections and they are all good, I even tride jumping the battery still no luck. Anyone else
Old Jan 7, 2006 | 05:09 PM
nismology's Avatar
1. A motor should start even with no motor oil, so i would correct the starting issue first.
2. Once you get it started, i would hook up an oil pressure gauge and make sure the pressure is to spec.
Old Jan 29, 2006 | 10:45 PM
Tyrexx's Avatar
update:
I charged the battery and got the car to start, It runs really rough and tries to kill at idle idle rpms. If you guys can think of anything else to try i'll do it because I'm getting a new motor anyway and there's no way to make this one worse.
Old Jan 30, 2006 | 06:06 AM
NaloGrove's Avatar
You could have gotten a bad starter. Try swapping it out again to make sure. Or have it bench tested at the parts store.
Old Jan 30, 2006 | 06:17 AM
NaloGrove's Avatar
update:
Sounds like bad timing, get that crank position sensor checked.
Old Jan 30, 2006 | 07:50 PM
colinchan167's Avatar
Air Mass Sensor
How about the Air Flow Sensor is going bad??
Old Jan 30, 2006 | 09:46 PM
venturous's Avatar
What kind of RPM's did you see when you missed a gear? Could you have floated some valves and bent them?
Randy
litch
123
Jan 4, 2024 07:01 PM
Miket2006
Mar 1, 2021 03:55 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
