im bored. lowered 4th gens come in !!
Old Jan 8, 2006 | 08:07 PM
VIP Maxima
ok lets get one of these going again. this time the topic is being lowered.
You know your 4th gen is lowered when ___________ .
the tow truck tells you to **** off.
fill in the blank........
Old Jan 8, 2006 | 08:16 PM
Akumachan's Avatar
I never narc'd on nobody.
You won't let passengers in your 4 door family sedan.
Old Jan 8, 2006 | 08:25 PM
sickmax's Avatar
aaron lavigne FTG
You tell ur date to walk down the driveway cuz u cant make it in......
Old Jan 8, 2006 | 08:28 PM
Poowill's Avatar
Your mechanic looks at your car and says..."jesus it looks like a freaking go-cart".
Old Jan 8, 2006 | 08:29 PM
nismology's Avatar
When your dash feels/sounds like it's fukcing falling apart over ANY bump.
Old Jan 8, 2006 | 08:40 PM
Fr33way™'s Avatar
Wild for Width
...you know (and use) the smoothest way home and to places you frequent
Old Jan 8, 2006 | 08:41 PM
ImmaSquashYou's Avatar
u can't go onto a lift cause all u hear is CLUUUUUUUNK
Old Jan 8, 2006 | 08:59 PM
DR-Max's Avatar
..........when you are always swerving and going sideways over bumps, dips, and driveways.
..........when you left your exhaust at the last dip you forgot to crawl over on.
Old Jan 8, 2006 | 09:04 PM
NmexMAX's Avatar
dot dot dot ...
When the other 4th gen in front of you looks as if though they're going to flip over due to the excessive body roll.
Old Jan 8, 2006 | 09:10 PM
dmontzsta's Avatar
Ford Only.
You have no way of lifting it at home, no matter what floor jack you have.
Old Jan 8, 2006 | 09:27 PM
mendon99's Avatar
tastey wheat
when your bottle jack doesn't fit under the suggested location
Old Jan 8, 2006 | 09:36 PM
DR-Max's Avatar
............when you get a flat tire in your driveway and you have to call AAA.
............when even a camber kit can't get your alignment back to spec.
Old Jan 8, 2006 | 10:13 PM
Nismotic's Avatar
Always sunny in philly
when you fart and you hear your front lip scrape.
Old Jan 8, 2006 | 11:48 PM
naijai's Avatar
when after jacking the car up with the stock jack your wheels are still on the ground
Old Jan 9, 2006 | 02:55 AM
Iron Scimitar's Avatar
Tha Snatcher
QFT!!!!!!!!!!!!!!!!111
Tha Snatcher
****** werd!
Old Jan 9, 2006 | 03:26 AM
MAXDADDY98's Avatar
Maxima.Org Bishes
......when you see the interior roof of a Corvette when you pull along side of it.
...... when you think you can go right underneath a Semi(I think we all thought of that)
Old Jan 9, 2006 | 03:40 AM
CreativeDesignz's Avatar
...when civics start to look like Suv's...\
...whenever i go up my gf's driveway i hit my cat because the wheelbase is so f'n long...
Old Jan 9, 2006 | 06:02 AM
ti2tmax's Avatar
Has his VINs memorized
...You park next to a stock Ford F-350, and you are looking at the car on the other side of him.
Old Jan 9, 2006 | 06:09 AM
MaximaSE96's Avatar
Maxima Owner
when u have to drive up on 2 2x4 pieces of wood in a stair like fashion to get the lowest floor jack u could find under the car
Old Jan 9, 2006 | 06:12 AM
ti2tmax's Avatar
Or they just load it on the flat bed anyway and scrape/crack the bejeezus out of your front lip stock or not!!
Old Jan 9, 2006 | 06:31 AM
...when u crack your cefiro lip 6 times in 2 months.
Old Jan 9, 2006 | 06:51 AM
suicidalspd99
When you successfully plow your driveway with your car.
Old Jan 9, 2006 | 07:39 AM
MAXDADDY98's Avatar
Maxima.Org Bishes
When you hit road Kill and drag it Home even tho you went over it think that it will just pass under the car
Old Jan 9, 2006 | 07:53 AM
buttonhook's Avatar
I did that in my mustang once. it cooked on the exaust!! unbelievable!! it took weeks to get that smell out of the car.
Old Jan 9, 2006 | 08:02 AM
Dubbya's Avatar
VK56 Inside
fat chicks cause scrapage.
Old Jan 9, 2006 | 08:06 AM
|Bijan|'s Avatar
UCF Lexus
...................when you get stuck
Old Jan 9, 2006 | 08:19 AM
Dubbya's Avatar
VK56 Inside
Where is the story behind that. The original poster never divulged it.
Old Jan 9, 2006 | 08:30 AM
Tha Snatcher
he was the original poster, LMAO
Old Jan 9, 2006 | 08:32 AM
|Bijan|'s Avatar
UCF Lexus
hahahahahaah
azzholes!
I did, and it's sooo 2005
Old Jan 9, 2006 | 08:42 AM
Dubbya's Avatar
VK56 Inside
I know. I was trying not to call him out on it.
Dubbya's Avatar
VK56 Inside
Originally Posted by bijangxe
hahahahahaah
azzholes!
Well for my sake please
Old Jan 9, 2006 | 11:05 AM
juani's Avatar
Rockin' VK56!!
When you go to smog test your car and smog guy tells you "your car's too low to drive on to the smog machine"
Old Jan 9, 2006 | 11:15 AM
Black Maxima
...when you take a right turn and your wheel comes off the ground.
Old Jan 9, 2006 | 12:11 PM
scrhale's Avatar
When you have to do a 3-Point in order to get out of your driveway.
Old Jan 9, 2006 | 12:41 PM
tavarish's Avatar
fwd gone rwd cr00
when you have do a 3-point to get IN your driveway..
when you know that at any time your exhaust note can change with a very nice bump in the road..
when speed bumps are approached with going at an extreme angle at 2 mph..
when you realize that the measuring the stock wheel gap in fingers is useless.
Old Jan 9, 2006 | 01:04 PM
RA030726's Avatar
I'm nutty for Nissans
your exhaust catches the road on fire.
Old Jan 9, 2006 | 01:20 PM
95bkackmax18s's Avatar
when you dont even want to take it out cause its to low, you cant go 'here or there' cause its to low, you cant take it on a lift, your co workers say "dam it looks low" and when you pull out the garage, you get a reminder its low. when jagoffs honk at you cause you do 2mph over railroad tracks.
Old Jan 9, 2006 | 09:20 PM
jasonv's Avatar
when you have to detour around puddles instead of driving over them
Old Jan 9, 2006 | 09:23 PM
Nissan 6's Avatar
if fat chicks as passengers make your car scrape
