way to test knock sensor?
Old Jan 10, 2006 | 07:43 AM
mendon99's Avatar
tastey wheat
is there a way to test a knock sensor if it is OUTside of the car? i have one right here, i could sell it. Im pretty sure its functional, id like to know for sure.
see a while back i got codes thrown for a ks (while the car was lagging and such), and when i replaced it, nothing changed at all. it later turned out to be just a coilpack, when i replaced that the car ran perfectly. so it obviously wasn't the ks...
any suggestions? i dont feel like ripping my hands up again
Old Jan 10, 2006 | 08:01 AM
NaloGrove's Avatar
Yep.. you'll need a scope though.. Knock sensors will react when a ping is made.
Old Jan 10, 2006 | 09:08 AM
mendon99's Avatar
tastey wheat
you talking about a scope that a doctor uses?
Old Jan 10, 2006 | 09:50 AM
NmexMAX's Avatar
dot dot dot ...
Check resistance...But a failing KS may still pass the resistance test.
Haynes manual helps in explaining how to test resitance.
Old Jan 10, 2006 | 10:22 AM
Dan's Avatar
Dan
No Longer Owns a Maxima
scope means oscilliscope.
Old Jan 10, 2006 | 10:42 AM
mendon99's Avatar
tastey wheat
ok, so the easiest way is to check resistance.
so the answer is maybe, or no then?
thanks guys
Old Jan 10, 2006 | 12:36 PM
NmexMAX's Avatar
dot dot dot ...
Maybe, since..
Old Jan 10, 2006 | 12:41 PM
njmodi's Avatar
Do I get a tax break?
A knock sensor that passes the resistance test may or may not be good.
A knock sensor that does not pass the resistance test is bad.
So depending on how yours tests, you'll either know nothing, or you'll know its definitely bad.
Old Jan 10, 2006 | 01:39 PM
Dan's Avatar
Dan
The best way to test (i'm speculating here) i would be to hook it up to an oscilliscope and make a pinging noise and see what happens on the scope screen.
Old Jan 10, 2006 | 01:41 PM
njmodi's Avatar
Dan - I agree that this is the most conclusive way, but I don't know if you'd still be able to determine if the readings are in spec or not...
When a KS fails, does it typically just go dead - i.e no response? if this is the case, then the scope will be conclusive in proving whether or not it works. If you can have a KS that is not dead but still not working properly (like an O2 sensor for example), then even the scope will not be sufficient.
Old Jan 10, 2006 | 02:12 PM
NmexMAX's Avatar
dot dot dot ...
Engine knock/ping is very sensitive and nearly impossible to detect. The KS is calibrated to such frequencies.
KS > you...
Old Jan 10, 2006 | 02:13 PM
njmodi's Avatar
Engine knock/ping is a very sensitive and nearly impossible to detect. The KS is calibrated to such frequesncies.
KS > you...
For a small plastic POS, it's a mighty little beast.. damn, they should be selling KS's in blue tiffany boxes
Old Jan 10, 2006 | 05:43 PM
phillyzj's Avatar
if you want to get rid of it, let me know.
mine threw a knock sensor code recently, but it hasn't come back, so i'm not sure what's going on.
Old Jan 10, 2006 | 09:45 PM
mendon99's Avatar
tastey wheat
damn, i dont have a scope, i guess ill have to cut my hand up again to check it. my guess is its still good
if you want it, make an offer, they go brand new for 100 on ebay.
Old Jan 11, 2006 | 07:08 AM
Fork's Avatar
Maximaler Experte
Sounds like it's your KS harness.
Old Jan 11, 2006 | 10:56 AM
seanish4042
i got the KS sensor code thrown at me too.
some guy on a another forum suggested that you can simple take out the bad one and place a .5mohm resistor where the KS goes to bypass the circuit.
can anyone explain this further?
Old Jan 11, 2006 | 11:01 AM
njmodi's Avatar
It can be done, but it's a bad idea. The knock sensor detects pinging and adjusts timing accordingly. If you fool the ECU into thinking everything is ok, when it may not be, you can cause damage to the engine.
Old Jan 11, 2006 | 11:12 AM
seanish4042
is the KS a difficult install? apart from the hand ripping stuff.
is a bolt involved or what.
Old Jan 11, 2006 | 11:18 AM
Dan's Avatar
Dan
As long as you have the right tools, it's easy. Get a long extension (like 16") and a flex socket or universal joint. You'll also need a magnetic or claw-type pickup tool.
Old Jan 11, 2006 | 11:24 AM
seanish4042
one more question...how tight do you make the bolt?
if its too tight its over sensitive and if its too loose its not sensitive enough?
Old Jan 11, 2006 | 11:27 AM
NmexMAX's Avatar
dot dot dot ...
231 ft/lbs
Old Jan 11, 2006 | 12:25 PM
njmodi's Avatar
231 ft/lbs
ballerchris510
Sep 23, 2015 08:46 PM
homeofbacon
Sep 23, 2015 07:17 PM
ac max 92
Sep 17, 2015 07:35 AM
