spring installation
Old Jan 11, 2006 | 11:02 AM
rome06's Avatar
spring installation
is there a write - up on spring installation......and this is a dumb question but if i dont have a spring compresson, cant you just use 2 floor jacks to compress the spring?? thanks
Old Jan 11, 2006 | 11:08 AM
Donald199's Avatar
NO becasue it will kill u
Old Jan 11, 2006 | 11:10 AM
MaximaSE96's Avatar
Maxima Owner
u cn get away with the rears...i wouldnt do it again...but the front u jsut asking for an injury
Old Jan 11, 2006 | 11:15 AM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
You can rent a spring compressor at a local auto parts store like kragen or autozone. There is a write up in the how tos.
Old Jan 11, 2006 | 11:20 AM
NmexMAX's Avatar
dot dot dot ...
Check the 5th gen stickys(how to's), housecor and a few other have a very informative write-up that is essentially the same procedure as the 4th gen.
Old Jan 11, 2006 | 11:23 AM
Preet S 22's Avatar
I30"T"
why would u risk that.........i think most auto stores rent out spring compressor for free.........u just have to put a full deposit
Old Jan 11, 2006 | 11:38 AM
rome06's Avatar
alright thanks guys
Old Jan 11, 2006 | 11:39 AM
maximus_96's Avatar
rent the compressors from autozone for free. when i did mine, i had to use it to take the stocks off, but the tokico springs went on w/o a compressor.
Old Jan 11, 2006 | 12:30 PM
ajcool2's Avatar
Using floor jacks to compress springs sounds real dangerous.
Old Jan 11, 2006 | 12:35 PM
mad_mod's Avatar
Yes, two jacks is a very bad idea. Just do the autozone thing or take it
to a machine shop. I'd just get the spring compressor myself.
Old Jan 11, 2006 | 12:36 PM
NmexMAX's Avatar
dot dot dot ...
Your idea = disfigured human body.
Old Jan 11, 2006 | 01:36 PM
rome06's Avatar
i just went got a spring compressor at autozone so i guese the rest of the night i'll be in the garage......does anyone know how long it takes before they settle??? I'll have pics of it in a few days also!
Old Jan 11, 2006 | 01:41 PM
BigLou93SE's Avatar
What setup did you go with? What kind of shocks?
Spring compressing is definately not something you want to fool around with - even with the right tools it can become very dangerous when used incorrectly. My girlfriends father once told me a story about someone in his shop using spring compressors the wrong way, which sent the shock (or spring, can't remember) through the wall. Something to think about...
Old Jan 11, 2006 | 01:50 PM
RA030726's Avatar
I'm nutty for Nissans
you guys have never removed springs without a compressor huh? there is almost no tension. the parts hardly move. not that i recommend it, but it sure as heck not going to kill you. most lowering springs dont need a compressor to be installed.
Old Jan 11, 2006 | 01:51 PM
BEJAY1's Avatar
Conecarver
FWIW, I just compressed my stock rears by hand. Ok, my 200lb body was on it but it was enough to get maybe an inch of movement.
Old Jan 11, 2006 | 02:00 PM
yofmatt's Avatar
I'm not familiar with max's, but some cars you NEED to have the spring compressor, unless you want to have your neighbor to find you dead with a spring shot through your face.
Old Jan 11, 2006 | 02:02 PM
mad_mod's Avatar
I've done rears without a compressor sure. But the sport springs on my
fronts needed to compress 3 dead coils. That's a lot of stored energy
I'd rather not risk letting loose in my face. Bit I'm a bit ****.
Old Jan 13, 2006 | 08:40 AM
rome06's Avatar
i got kyb agx shocks/struts with megan racing springs.....i havent seen them on a maxima before but my friend has them on his 2004 mazda 6 and they look and ride great, so i thought about trying them out.....anyways the ride is very comfortable and how long does it take before they settle? thanks
Old Jan 13, 2006 | 08:48 AM
MaximaSE96's Avatar
Maxima Owner
just cehcked them out on the megan website....lowering isnt bad about 2" but for my uses the rates are too soft well the rears atleast..wodner how they compare to Eibachs....but gotta love the orange
http://www.meganracing.com/products/...asp?prodid=285
Old Jan 13, 2006 | 09:11 AM
dgeesaman's Avatar
Maintenance Monster
Sure, you can try it on reassembly. You won't hurt anything by *trying* to compress the spring and going nowhere. And if you're going to compress it with your body weight, you need to be able to compress the mount all the way down on the strut shaft - do NOT use the nut on the end of the shaft to tighten down the parts. That could damage the threads and cause the nut to come loose later.
However, if you're disassembling, do not take it apart w/o compressors since you can't be sure how much the spring will want to kick. Even if you think they are lowering springs, treat them like they are heavily compressed. But I personally don't miss people who do stupid things and die, so it's your choice.
Dave
Old Jan 13, 2006 | 11:17 AM
rome06's Avatar
how long does it usually take for the springs to settle??????
Old Jan 13, 2006 | 02:25 PM
dgeesaman's Avatar
Maintenance Monster
I've never heard of settling time on a properly installed spring.
Dave
Old Jan 13, 2006 | 02:43 PM
RA030726's Avatar
Originally Posted by dgeesaman
blah blah blah
i hope you arnt trying to preech to me, ive done so many installs..... but like i said, i dont recommend it. my point is youre not going to die. loose an eye.... maybe
Old Jan 13, 2006 | 02:44 PM
RA030726's Avatar
Dave
springs arent supposed to settle, but the rubber parts may.
Old Jan 13, 2006 | 06:33 PM
mastajonjon's Avatar
Actually, I believe the springs do settle...I have the tein s-techs with kyb-agxs and it took about a week to fully settle...some may disagree, but this is my personal experience...hopefully this answers your ? about settling...
Old Jan 14, 2006 | 12:11 AM
1996blackmax's Avatar
I have read that I quality spring will not settle (can't remember if it was on the H&R site or not). I think it may be more in line with what Jsutter mentioned about the rubber parts.
MaxLife17
Jun 27, 2019 01:37 PM
BkGreen97
Apr 2, 2016 05:47 AM
Hdnseek
Sep 9, 2015 05:55 AM
lowpost99
Sep 8, 2015 05:06 AM
Johnny9595
Sep 3, 2015 05:18 AM
