urgent: o2, bank 1 sensor 2, which o2 from oxygensensors.com? link.
Old Jan 12, 2006 | 12:28 PM
sook's Avatar
need to replace o2, bank 1 sensor 2, which of the o2s on this page do i need to order?
https://www.automedicsupply.com/cata...9ce82c756a42f5
Old Jan 12, 2006 | 12:39 PM
KRRZ350's Avatar
"Sensor located in front manifold/exhaust pipebefore catalyst - two required"
That's suspect, since there is a difference between the two, you should just call them, or take out your sensor and give them the bosch part# on it. IMHO I'd get a Bosch or an overpriced bosch one with the nissan logo stamped in it.
Old Jan 12, 2006 | 12:42 PM
konak85's Avatar
I bought the denso from there and it works fine. The two upstream sensors are identical and there is only one downstream(the one on the cat converter)
Old Jan 12, 2006 | 12:46 PM
sook's Avatar
the mechanic told me that the one that was out was the cat one..
would that be bank 2 sensor 1, and i just got it switched in my mind?
Old Jan 12, 2006 | 04:39 PM
ManualMaxima's Avatar
5th Gen till she dies!
yes taht would be the rare oxygen sensor.....depending on if it is calispec or not, if it is fed spec.....then it is the one of the cat.....if it is cali spec....then it is the rear sensor, on cylinder 1 side
Old Jan 12, 2006 | 06:09 PM
95GLEMAXX's Avatar
i got the walker one and it fits and works fine
Old Jan 12, 2006 | 06:45 PM
konak85's Avatar
that would be the down stream
Old Jan 12, 2006 | 09:21 PM
sook's Avatar
my car is fed spec. so, downstream one, oe, walker. yes?
Old Jan 12, 2006 | 09:27 PM
njmodi's Avatar
Do I get a tax break?
What was the exact code you got? i.e. so we can double check what O2 sensor you need to replace.
Old Jan 12, 2006 | 09:44 PM
konak85's Avatar
yes if the code is for either one of the two upstream sensors. Fed spec Maximas have 3 02 sensors, (2 upstream and 1 downstream)
Old Jan 12, 2006 | 11:12 PM
sook's Avatar
the mechanic used the scanner, i didnt pull the code from the ecu
and konak, i asked if downstream, and you said yes if its upstream, what did you mean?
Old Jan 13, 2006 | 06:54 AM
njmodi's Avatar
sook - you are sure your car is fed spec right?
Here is a pic of the O2 sensor locations in a Fed-spec Maxima:
http://www.courtesyparts.com/A32_O2-sensors.html
Is the CEL still lit? if yes, pull the codes and report back.
Old Jan 13, 2006 | 10:14 AM
mjb95maxse's Avatar
i got a denso one and it also fit just fine
Old Jan 13, 2006 | 10:49 AM
sook's Avatar
yes, im sure its fed spec. just checked again.
and the ses is light is still lit, the cel never was. ive never pulled a code before, im kinda iffy futzing with the ecu.
Old Jan 13, 2006 | 10:57 AM
njmodi's Avatar
SEL = CEL (just different terminology for different years).
Go to autozone - they'll pull the code for you.
Old Jan 13, 2006 | 11:04 AM
sook's Avatar
i thought there was a difference between the "service engine soon" and the "check engine light." like the ses means fix it when you get the chance, the cel means fix this asap, and blinking cel means pull over and tow this b!tch
but i dont know where i got that idea
and mine is urgent because i need to order it, get it put in, pass emissions, and renew my registration before the 31st
Old Jan 13, 2006 | 11:05 AM
njmodi's Avatar
nope. same thing.
Old Jan 13, 2006 | 12:30 PM
machinehead's Avatar
which should i get, the denso or the bosch or oem nissan?
my03maxima
Jul 28, 2024 07:40 AM
jmlee44
Oct 2, 2022 02:13 PM
hayne
Oct 5, 2015 11:53 AM
