Headlight Removal Issues
Well, I already somehow managed to snap off the 2 outer bolts holding my driver's side headlight in. I'd prefer not to do the same to the other side, but no big deal so long as the headlights come out.
My question...any tips on how to get the inner bolts out? I'm speaking of the ones near the radiator support that are practically hidden from view. I'd prefer not to snap them as well and want to know the best tools for the job to get them off. I feel like such a n00b asking this sort of crap, but...oh well...Basically, what kind of tools do I need to snake around that huge wiring harness on each side and all that jazz.
Thanks guys.
Thanks guys.
Moving the harness...don't think so. If all I need is an extension or maybe a swivel extension then great. I've never taken my headlights off...do you HAVE to have off the grill to take out the headlights?
Yeah once I took it over to the garage we got things figured out quite easily. I have my new projectors in...but I think I messed up some plugs or something because they won't turn on
Originally Posted by bijangxe
NOoooooooooo!
Oh well...take them bishes back out and re-wire
These are what I can't figure out:
See the black plug? What goes there? I have nothing else to plug into it. See the little blue plugs? They have ends that look like they should fit into those black plugs, but the way things are setup it makes no sense. Should a fuse go in the black plug? I would have thought he'd include a fuse if it was needed...
Hmm
Yea it LOOKS like a fuse fits right in there, almost like a power cable for an AMPLIFIER. (Just btwn 5-40 amps) ?
Do you hear a hi-pitch squeal when you attempt to turn them on?
Also....Im assuming the black plug in is "female" right? (looks like it but hard to tell from blurryness)
Hmm
I don't remember hearing a squeal. Should I have?
Now I need to figure out what kind of fuse I need...
Damn,
I wish I could be more help but I havent ever really done that kind of wiring besides hooking up my HIDs.
Just bounce over to Wal Mart / Walgreens...whatever's open....you know what fuses to look for...I'd start w/ 10 amp and work my way up if they blow...
Just a suggestion, hope it works, I wana see!
I wish I could be more help but I havent ever really done that kind of wiring besides hooking up my HIDs.Just bounce over to Wal Mart / Walgreens...whatever's open....you know what fuses to look for...I'd start w/ 10 amp and work my way up if they blow...
Well. Not all is well in the kingdom of HIDs. Yes, they turn on. That's about it lol. The headlights need aimed BADLY...they are aimed extremely low (REALLY low) and very far to the left. Also, for whatever reason, the high beams aren't working. I know I hooked up the bi-xenon solenoid, too...so I'm not sure what's up. Oh well, low beams will be fine for now once I aim them.
CUSTOM JDM cross-eyed bi-xenon HID project0rzz!!Save the wiring for the daytime! hahah
Oh well...all is fixable, I suppose. Plus they look badazzz
nice nice. i had to learn the hard way too how to remove headlights. When i bought a set of headlights and did the AE to them. I removed my headlights twice and both those times the grille went str8 to the ground when i was tryint to remove it. Next time you do it, remove grille if you can first. Then corners and then actual headlights works 10 times faster.
How much was the parts and do you mind listing and sourcing them as well? i know they have pre-made sets at hidplanet. But i was just curious. I wanted to get something with TSX projectors.
All prices include shippping...
E46 bi-xenon projectors: $135
E46 ballasts and ignitors: $173
Phillips D2S 4300k bulbs (new): $65
Used 97+ Headlights: $110
maxgtr2000's retrofitting (including bi-xenon harness and angel eyes): $140
Shipping to maxgtr2000: $18
So total: ~$650
Projectors came from an .org member, as well as the headlights. The ballasts+ignitors and bulbs came from eBay.
So total: ~$650
This morning was not good. Did anyone notice that in the pictures, the passenger side was dimmer? I figured it was in need of aiming...but...
This morning I turn on my headlight...and only see one come on. Well, I pop the hood and guess what? There lays the capsule in the engine bay. Worse yet, my coat accidentally touched it and melted a piece off. The melted fabric got stuck to the bulb and now the bulb is no good. So I'm now with only one headlight til I get another bulb off ebay or something.
I will take daytime pictures of the headlights today, though...
Originally Posted by njmodi
Can you replace just one bulb (in terms of light color/brightness), or should you replace them in pairs...
Wish I would have caught what you were saying when you said one was dimmer, I thought it was the aiming. D2s bulbs can be tricky to seat sometimes, always make sure you feel a little click as the bulb holder seats on the projector.
are those range cover bezels? and are those LED angel eyes? i'd be very careful with them because LEDs are very sensitive to heat and if they're on while your hid bulbs are on, you'll shorten the lifespan dramatically. maybe you can wire them so they're off when the hids come on. the hid will overpower the leds anyways
Wow...sexy x 1,000,000,000
I had major problems taking my headlights out when I did the AE mod and I undid all the screws that aim them making problems worse
Glad you figured it out and I hope all the other issues get sorted out too...I'm sure those lights are well worth the money!
One day for me...
Glad you figured it out and I hope all the other issues get sorted out too...I'm sure those lights are well worth the money!One day for me...
Tonight driving home, I had only one headlight on since the other bulb had to be removed. With it aimed really, really low and really far to the left...it still light up the road wider and farther than my old 9004's did with overwattage bulbs
This is from ONE headlight!
Wow, that's crazy! My headlights are so crappy...they're covered in road salt so my visibility is way down plus I have to drive about 20km of dark roads to get to work. Maybe I should consider this instead of rims...???
Make sure you keep the receipts for everything just in case you ever have an accident and they're damaged...that way you have proof of how much you spent and hopefully you would be able to get the money back.
Originally Posted by Tatanko
Yes, those are homemade bezels maxgtr2000 made for me. Yes, those are angel eyes. They were going to be wired to come on with the clearance lights so I could run them with just them on or with my fogs. They are a slightly bluer shade than the HIDs, so I was going to allow them to stay on with the HIDs. I didn't see heat being an issue though, because of the bezel and the projector glass trapping it all in.
of course.
